Old 05-29-2005, 03:08 PM
jerso06 jerso06 is offline
98 rear wiper
rear wiper arm stopped working. Fuse ok. Maybe rear wiper motor?? Can anybody tell me where it's located and how to check/change it pelase. Thanks in advance.
Old 08-27-2005, 10:58 PM
jerrygibb jerrygibb is offline
Re: 98 rear wiper
i had the same thing happen to mine-went to the bone yard and got one-it was bad too---took mine off used some wd40 on the shaft-had to tap it with a rubber hammer a few times.Some how water had leaked past the rubber seal.It saved me about 40+dollars.Now when i drive it i turn on the rear wiper once in a while to keep it from seizing up.I also found out the wiper won't work when the rear hatch is open.the rear panel is held in place by about a dozen plastic "christmas trees". if you bust one,replacements are available at the part store.
hope this helps----good luck
Old 08-28-2005, 11:39 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: Re: 98 rear wiper
Yes, your output shaft is frozen to the bushing. I fixed two Ford rear wipers by pulling the wiper motor and lubing the shaft. I would also clean up the brushes and comutator (spelling?).
Dan
