Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 05-29-2005, 02:48 PM
moltra moltra is offline
Question 1997 fuel pump problem
I have a 97 Jimmy where the fuel pump failed. I have a replacement pump for the actual pump, but when i disconnected the fuel pump from the fuel lines, 2 of the 3 plastic connections broke. Would a rubber fuel line and hose clamps work to fix the fuel lines where they broke. Or do I need to replace the whole fuel pump assembly.
Old 06-01-2005, 10:33 PM
JimmySLS's Avatar
JimmySLS JimmySLS is offline
Re: 1997 fuel pump problem
Replace the assembly...rubber hoses and hose clamps won't hold up to the fuel pressure...
Old 06-02-2005, 06:56 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Correct. Rubber hoses can't handle the pressure. You need a new sending unit. Don't do stuff half assed or you will regret it later.
Old 06-14-2005, 08:54 PM
replaced fuel pump
I replaced the fuel pump and the truck started fine and drove about 15 miles and then it started surging. It dies about 2 minutes later. I repaced the fuel filter and no change. When it dies, if I wait about 1-2 minutes and restart the truck it runs for about 2-5 minutes for dying again. Any and all help would be appreciated.
Moltra
