Old 05-29-2005, 12:36 PM
bigdinz's Avatar
bigdinz bigdinz is offline
Oil Smells Of Fuel
I changed my oil today and did a flush as well. When I drained the oil the first time I swore it smelled like it had gas in it. What would be the cause of this? All "tune-up" parts have been changed.
Any ideas?
Old 05-29-2005, 12:49 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Oil Smells Of Fuel
The oil without the flush smelled like gas?
Old 05-29-2005, 10:58 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
What are all the tuneup parts your replaced.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-29-2005, 11:02 PM
bigdinz's Avatar
Yes the first(bad) oil smelled of gas.
I replaced plugs,wires,cap&rotor,pcv & fuel filter.
Old 05-30-2005, 12:05 AM
BlazerLT's Avatar
AF -Advisor
did this gas smell come from the oil with the flush in it?
Old 05-30-2005, 05:47 AM
bigdinz's Avatar
Re: Re: Oil Smells Of Fuel
Now I know some people in the world aren't that bright but.... I am not one of those people.
Definitely not before I added the gunk. The old oil!
Thanks for the replies!!
P.S. No more dumb person questions..... o.k.?! LOL
Old 05-30-2005, 02:16 PM
BlazerLT's Avatar
AF -Advisor
Please relax on the defensive replies, it was only a question.
If your oil has a strong gas smell, this in part is normal, it a certain extent.
I would replce the PCV valve seeing it is there to remove those post combustion gases for reburning instead of them being impregnated into the oil.
Old 05-31-2005, 08:48 AM
bigdinz's Avatar
It was a joke. Did you notice the (Laugh Out Loud)lol at the end? It WAS a silly question to ask in the first place. Just letting you know that I know more than you thought I knew.
Thanks again for all your help!!!!
Old 05-31-2005, 09:41 AM
crazycory1 crazycory1 is offline
Does your truck run rough? When you drained your oil, was the oil that first came out thinner than the last of the oil that came out. My jeep had the same problem, a bad fuel injector. The fuel injector was dumping so much fuel that that the fuel was going through the rings of the piston into the oil pan. But that was on my jeep, I don't know if it can happen on an s10. My jeep had rough idle though.
Old 05-31-2005, 09:42 AM
Does your truck run rough? When you drained your oil, was the oil that first came out thinner than the last of the oil that came out. My jeep had the same problem, a bad fuel injector. The fuel injector was dumping so much fuel that that the fuel was going through the rings of the piston into the oil pan. But that was on my jeep, I don't know if it can happen on a blazer. My jeep had rough idle though.
Old 05-31-2005, 02:34 PM
redwheeler's Avatar
redwheeler redwheeler is offline
ok ok most used oil smells like gas because of blow by from the use of the engine
Old 05-31-2005, 10:01 PM
BlazerLT's Avatar
AF -Advisor
PCV valve should fix this up.
