Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-29-2005, 11:08 AM
TalonTsiAwd93 TalonTsiAwd93 is offline
Boost control solinoid
Where Is The Boost Control Solinoid Located And What Would It Do Ir Romoved?
Old 05-29-2005, 02:55 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Boost control solinoid
I thought on the 1Gs it was on the stock airbox. I can't be sure though, I dont think I've ever seen a stock 1g in person On the 2g its on the passenger side framerail, somewhat under and behind the airbox area.
Its how the ECU controls boost. Follow the WG vac lines, should lead right to it. Some poeple remove it so they can run an aftermarket boost control solenoid. If you just remove it, you end up with less boost pressure, just the WG spring pressure. On teh 2g, there is a restrictor in the solenoid that can be removed to add 1 or 2 psi. See www.vfaq.com for details.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
