Old 05-28-2005, 11:10 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
bad idle after install
Ok, here's the deal. Yesterday, I installed a k&n fipk air filter. After I put it in,I went to take it for a test run. I noticed that as soon as I started the car, my rpm's dropped vey low from the usual 800-1k to about maybe 100-200. It didn't stall out or anything. I made sure everything was tight and clamped up. My friends told me this is normal, and that the computer is just getting used to the added airflow from the stock pos.
Today, it ran fine, no rpm drops and it sounds great. But, after work and when I got to my house, I pulled into the driveway getting ready to park, and the rpm's started to drop again!
Is there something wrong, or is the computer still getting used to the airflow. If it's the airflow, approx when do you think it will be fine?
Thanks!
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 05-28-2005, 11:22 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: bad idle after install
Well, from what ive read, the computer takes about 5-7 days to recalculate everything and adjust...but with an air filter, you shouldnt be getting that. Ive never had this problem
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 05-29-2005, 01:01 AM
kjewer1 kjewer1 is offline
AF - Advisor
No time is required for airflow changes on MAS equiped cars. For MAP cars, the ECU doesnt recognize airflow changes easily unless pressure changes. So that is not the issue.
I'm assuming you have checked all the obvious things, like plug the MAS back in, etc? After 6 years with the 2g, I'm still not immune to overlooking the simple things.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
