Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 05-28-2005, 10:40 PM
kycabledog kycabledog is offline
Send a message via Yahoo to kycabledog
Question Changing 2.7 to 3.2
In the process of changing over from a blown 2.7 to a 3.2 and need some help. The 3.2 engine has a green wire with a white trace coming out of the drivers side plentum along with two black wires going to ground. It's located just below the vacuum hook ups on the drivers side. The problem I have is the green wire was broken or cut (don't know which) and I have searched everywhere to try and find out where it go's or where it terminates. I have ruled out it being a ground.
Would appreciate any help from someone that has a 3.2 engine.
Old 05-29-2005, 05:52 PM
tdawg tdawg is offline
Re: Changing 2.7 to 3.2
Check out dodgeintrepid.net, and post in thier forums. A few of the guys in there have done this swap, or done the 3.5 swap. Also, there was a kit avalible for a while on dodgeintrepid.net to do the swap you were working on. I don't know how to do it, but can point you in the right direction. check it out.
-Taaf-
