Old 05-28-2005, 08:00 PM
gerob2 gerob2 is offline
well cylinders
A wheel cylinder that only pushes on one side needs to be replaced - right?
Old 05-28-2005, 11:47 PM
Schrade Schrade is offline
Re: well cylinders
not necessarily, gerob. The bore can be polished with emory paper, if not pitted inside. Seizure on one side usually is due to moisture/water in the cylinder bore, and is common in vehicles that were idle for a while. If you're lucky, the bore is okay, and you've just got rust caked on the rubber plunger inside the cylinder.
Old 05-29-2005, 08:33 AM
Thanks for the info I'll take a look at that.
Old 05-31-2005, 12:18 PM
buckeyboy buckeyboy is offline
Re: well cylinders
Price one first. some I have seen are like 20 bucks not worth rebuilding .
