Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 05-28-2005, 07:35 PM
n6e6i6l n6e6i6l is offline
Question transmission filter change.
Hi,
I'm trying to change the automatic transimission filter in my 93 4runner (3.0L V6). I have drained all of the fluid and removed the, what seemed like 85, bolts holding the pan up.
Unfortunately, nothing is moving. I can't seem to get the pan off to get at the filter. Am I missing something? Any suggestions would be helpfull.
Thanks in advance,
Neil.
Old 05-28-2005, 08:14 PM
Do I need to remove the filler tube? If so how and where do I detach it?
Thanks again.
Neil
Old 05-29-2005, 02:47 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: transmission filter change.
It may separate into two halves, upper and lower. Also, might be the sealant holding the pan on to the tranny case.
I have been told that you don't have to replace the transmission filter. It is only a screen to prevent large particles from getting into the pump and valve body.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 05-29-2005, 03:56 PM
Re: Re: transmission filter change.
How do you get the sealant off?
Old 05-30-2005, 02:35 AM
Tomsriv Tomsriv is offline
Get a long scraper or flat-head screwdriver and carefully pry it off. On my 2000 4runner I was told at the dealer parts department that I didn't need to replace the filter. Mine had 100,000 miles on it and their was nothing in the screen.
Old 06-03-2005, 07:52 PM
gmanone gmanone is offline
Originally Posted by n6e6i6l
Hi,
Thanks in advance,
Neil.
When I change mine out on my 92 I had to remove the crossmember to get the pan to drop all the way out.
Old 06-07-2005, 12:01 PM
Got it out thanks!
