Go Back   Automotive Forums Car Chat > Ford > Contour
Old 05-28-2005, 07:05 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
dropped in an engine and no start
I just bought a 96 Contour 2.0 DOHC 5 speed off my cousin for about $400 because it had some major issues. He overheated it badly and blew the head gasket and probably cracked the head, coolant shooting out over flow jug and oil shooting out the air box.But anyways I had plans to rebuild the motor but the bolts were pretty much welded into the engine and were impossible to remove. So I bought a used engine, I wanted a rebuilt motor but cant afford one and this car is just for everyday driving since my Saturn is getting ready for shows. Ive replaced the clutch along with the motor because of the age of the old one. I got everything installed and hooked up went to start it and all I got was the engine to crank. I checked for spark, none, checked for fuel pressure, plenty. I figured well the coil or wires are bad(brand new wires that were on the car), so I swapped the coils and still no spark, same with the change of wires. I checked to see if there was any voltage to the coil and there was same with the injectors. I checked relay terminals(not the relays themselves but have swapped them around to see if there would be a change) and all fuses and everything checked out fine. Relays click, fuel pump whines, engine cranks, voltage to everything but no start???? How in the world can it not start? Timing is fine. I really dont think there is an anti-theft system holding it up, this is a very basic GL model, but all I can come up with is the PCM needs to be flashed. If these cars feel that there is going to be serious damage to the engine will the PCM just shut down and not allow you to restart till its flashed or something? I have no idea what to do, if I dont get any really helpful information, it will have to go to the dealer for repairs(which with this problem I doubt I got the money to fix it) and I work at a garage but this problem seems to be more of a dealer only repair.
Old 05-30-2005, 10:00 AM
01EB5.0 01EB5.0 is offline
Send a message via AIM to 01EB5.0
Re: dropped in an engine and no start
TMy 96 has a quirk where the engine will not even crank unless you press the unlock button on the remote once your inside the car. It only does this occasionally. I wonder if it could be some sensor like the crank position sensor or something thats not connected or whatnot, preventing the PCM from knowing the engine is even turning?
Old 06-01-2005, 11:59 AM
all sensors and grounds are connected and there is voltage to all sensors, coils, and injectors. all fuses and relays are working. the only thing im not sure about is the fans. typically on most any car the fans kick on to go through a check then kick off but these ones never have nore is there ever voltage to them but there is voltage to the relay for it.
Old 06-02-2005, 11:36 AM
I don;t remember my fans coming on unless the car is getting warm, but then again normally I'm inside the car as it's being started...I don;t think the fan would prevent the car from starting though...
Old 06-02-2005, 05:42 PM
Jason43's Avatar
Jason43 Jason43 is offline
What years is the new motor?
Just go to contour.org
1999 Ford Contour SVT
Old 06-05-2005, 10:34 PM
95. all hook ups seemed the same except for the knock sensor so i swapped it out
