Old 05-28-2005, 06:06 PM
kzuby kzuby is offline
vilent idle
2002 Taurus 3.0 litre, Check engine light went on 3 days ago, checked at autozone, code read - EGR valve, checked valve today-looked good but I cleaned it anyway with some carb cleaner. It seemed to function fine. Now I started to notice the RPM's jumping up and down at idle. Its so bad now that the whole car jumps back and forth at red lights. It seems to drop idle, almost stall, then jump up again. It does this pretty rapidly. The only thing I can think of, is the idle position sensor. Please help! Has anyone had this happen before??
Old 05-28-2005, 07:50 PM
sfontain sfontain is offline
Re: vilent idle
P0401?
You need a DPFE sensor from Ford.
Old 05-29-2005, 09:20 AM
Yeah, the code was 0401. I decided to relace the valve and gasket. Idles perfect. Now what is a DPFE sensor and how much does it cost? Is that the only way to clear that code?
Old 05-29-2005, 03:54 PM
Re: vilent idle
Oh interesting. EGR valves don't fail terribly often on these cars. Well, if the EGR valve fixed it then I would recommend driving for a week or so and see if the CEL goes away. If not, the DPFE sensor I think is around $80 +/- from the Ford dealer and measures the pressure difference on both sides of the EGR valve. They break a LOT, but if yours is good then if the EGR valve fixed it, the CEL should go away after several driving cycles.
Old 05-29-2005, 07:26 PM
denisb denisb is offline
Make sure it's not a dissconnected vacum line. Mine had a similar problem and it was a vacum line. If it just started to act up after you looked at your EGR, you might of accidentaly pulled out the vacum line.
Denis
Old 05-30-2005, 12:27 PM
Cvkitty76 Cvkitty76 is offline
Unhappy Re: vilent idle
See my response in a prior question statin taurus stalling. This is the way my problem started and still exits. except it steadily gets worse. and then it dies at each light.
Old 06-01-2005, 08:16 PM
Wodinator Wodinator is offline
Re: vilent idle
You can pick up a DPFE sensor at Auto Zone for around 60 bucks. Very easy to remove/install. I had the same trouble code, it went away after installing the new DPFE sensor.
Old 06-02-2005, 06:49 AM
Don't buy an aftermarket DPFE sensor. This is one part you need to buy as original equipment.
Old 06-02-2005, 06:55 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: vilent idle
If you buy aftermarket, make sure it is Motorcraft. That is Ford OEM part.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
