Old 05-28-2005, 03:40 PM
djmp djmp is offline
Fuel pump regulator
My son bought a wrecked car and it will start and then cuts off
this is a saftey thing and he can not tell which regulator it is there are about 4 in the same place
we ordered a cd but it did not help
can anyone tell me which one it is or have a diagram that tells
also would like a book chiltons on this model no cd as they are a pain
pease email me at [email protected] or tell me where to go
thanks
Jane
Old 05-28-2005, 06:33 PM
Hotshot8792 Hotshot8792 is offline
Re: Fuel pump regulator
thanks
Jane
First thing, check and make sure that the MAS is plugged in, cause if its not plugged in, then your car will start but then shut off after a couple of seconds. The MAS is the box right after the air filter.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 05-29-2005, 04:38 PM
Re: Re: Fuel pump regulator
Thanks for getting back to me
but this did not help
does anyone have a diagram for the relays that has the fuel pump relay in it
Old 05-31-2005, 02:16 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
are you sure its the fuel? i had a similar problem and i was pretty sure it was the fuel. turned out it was actually the timing!
does the car actually start? or does is sound like it wants to start?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
