Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 05-28-2005, 01:53 PM
swiftskater swiftskater is offline
E-brake burnouts?
Hi everyone i am have a question on using the E-brake to burnout. but first let me tell you what has happened so far when i attempt them. first time i tried i was in a level parking lot pulled the E-brake up about hlf way then gunned it. the car moved because i didnt realise i had to pull the brake up farther. so i decided that i wasnt going to attempt another one that day, so yesterday i go for it again i pull the E-brake all the way up and the car holds but the wheels dont spin i had it revd high enough where the tires should have spun but instead i just herd the motor going like normal. once i noticed i wasnt spinning i stopped in fear that i was going to mess up my clutch of which i think i did because it smelt like fish after. But the wierd part was there were no abnormal sounds comming from the engine when this happend like no grinding or squealing .
could someone please tell me what i did wrong or how to do these properly because i am afraid i messed my clutch but there is no evidence to support it.
Old 05-28-2005, 01:57 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: E-brake burnouts?
Have you thought about your tires being GOOD STICKY TIRES?!?!
....It has been a LONG time...I want to move to FL or Japan.....
Old 05-28-2005, 01:59 PM
no because they are stock tires. although they are low on air compared to recomended psi.
Old 05-28-2005, 02:08 PM
drewh4386's Avatar
stock tires are good enough to be sticky. Also in order to spin the tires pull the brake as hard as you can and then PUNCH the gas pedal. IT won't work good with sticky tires. DId your car pull foward with the revving? IF not, were you even in gear?
Old 05-28-2005, 02:11 PM
i had the e-brake all the way up and the car didnt move i am positive i was in gear because i tried once and didnt move so i double checked everything. i think i dropped the clutch at 4,000 rpms which is normally more then enough for me to do a regular spin.
i am just worried about the clutch if anything, if i were to mess it up would there be a distinct sign or sound when it happens?
Old 05-28-2005, 02:22 PM
drewh4386's Avatar
No sound but a smell of a burnt clutch. it is strong.
Old 05-28-2005, 02:24 PM
drewh4386's Avatar
oh and dropping the clutch is going to short the life of your tranny and clutch.
Old 05-28-2005, 02:27 PM
well it was strong smell, so instead of dropping it just do it like i normaly would drive?
Old 05-28-2005, 02:32 PM
drewh4386's Avatar
How about this, stop while you are ahead. When you burn the clutch out, unless you have the money, or you know how to fix it or somebody who can,
it is going to be a $1000 dealership fix. unless your car is under warranty.
and about the ? above, you can but it would be harder to keep the car still. Especially with good front tires.
Old 05-28-2005, 02:38 PM
yeah i realized it isnt worth it thanks for your input.
Old 05-28-2005, 03:42 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
this is the normal way people do this. launch the car at 4000rpms THEN pull the ebrake. you have to get the wheels spinning before you pull the ebrake.
you cant sit there with the ebrake up, then drop the clutch. nothing is going to happen.
Old 05-28-2005, 05:35 PM
95_GS_5Spd's Avatar
95_GS_5Spd 95_GS_5Spd is offline
My Way
Here's how I do it....Grab the e-brake. Pull it all the way to top. Have your shifter at first. Rev to 5k. Dump the clutch. Sit there smokin all day long. Just drop the e-brake when you want to burn away.
Old 05-30-2005, 06:21 PM
2002EclipseRS's Avatar
2002EclipseRS 2002EclipseRS is offline
Re: My Way
yall are idiots....wearing your clutch, e-brake, tires, and putting strain on the tranny....why do this? Thats like me running into walls to hear the sound even though i know ill get a bruise on my head...its just plain dumb.
Made the switch from Mitsubishi -> Honda (acura)....so glad i did!
Old 05-30-2005, 06:24 PM
drewh4386's Avatar
Yall? you mean him?
Old 05-30-2005, 10:22 PM
Re: Re: My Way
how do you go off and call us idiots? he asked how to do it. not one person here said that it was a great thing to do. its his car. if he wants to destroy the tranny just to do burnouts, then thats fine with me. im not going to be paying for it.
