Old 05-28-2005, 01:21 PM
blazinLT blazinLT is offline
Question for BlazerLT????
Hello, Mike in Tx. I have a Blazer exactly like yours, changed the fuel pump in tank, but didnt change the Pulsator, seems to run a little better but feels like it loses prime somewhat. Pulsator Leaking? Do you actually need this Pulsator? or would a piece of hose directly connecting them be a better decision?
Thanks,
Mike
P.S. I have changed the CPI and Nut kit.
Old 05-29-2005, 05:43 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Question for BlazerLT????
You will need the pulsator. Also have you checked your fuel pressure? The checkvalve on the sending unit may be bad. (Not critical) but just makes for a slightly longer cranking time.
Hook up a pressure tester at the shrader valve. Turn the key to run. Pressure should run to 56-60, turn key off. Watch how fast pressure drops.
