Old 05-28-2005, 01:11 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Metal Scraping?
Alright well this problem just started a couple of days ago. I origianlly thought my radiator must be going out but now I'm not so sure. There is this extremely loud scraping sound. It sounds as if the piston was grinding at the wall or something like that...But the weird thing is that it changes from when the radiator fan turns on and off. When the fan is off I hear this high pitched metallic sound but when it is running the engine knocks really hard, like visible shacking corralating with the knocking. Any ideas? Is it the radiator? Because the radiator is about to go because it has started cracking and becoming discolored. Also I dont hear any sounds comming out of the exhaust so wouldnt think that it was a cylinder going...Thanks again.
Old 05-28-2005, 01:55 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: Metal Scraping?
Yo buddy, what kind of car do you have and what year?
....It has been a LONG time...I want to move to FL or Japan.....
Old 05-28-2005, 01:59 PM
Turbodog97's Avatar
Just a Neon
sorry, I have a 95 Gst Eclipse w/ about 106 thousand miles.
Old 05-28-2005, 07:15 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Metal Scraping?
now that you have told what type of car you have put that info into your signiature so nobody jumps on ya again about it....as for your problem endlessheart666.... not a clue...doesn't sound good
Where is the higher pitch noise coming from?
I assume you have checked your oil and antifreeze/coolant?
What were you doing to the car when it started? Pounding on it from a light? What MODS have you done to the car? Put that info into your signiature also...The more info we get from you the less time it will take to diagnose your problem...
Have you done basic things like new plugs and are they gapped correctly? That can do it if the aren't gapped right but that is usually under boost....and won't cause it to make high pitch noises...
Maybe the Tbelt jumped a tooth.... has the Tbelt been replaced? I don't know just throwin out questions...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 05-28-2005, 11:32 PM
Turbodog97's Avatar
Just a Neon
ya it has brand new performance plugs and wires, and a brand new timing belt, water pump and clutch. The car has slight mods like exhaust 1g head swap and etc. The coolant if full and the oil is good also, just changed it 2 weeks ago. I dont know what it could be. Ive heard of the whole Crankwalk issue but something leads me to believe thats not it. Ive had none of the symptoms and if the sounds I was hearing was the thrust bearing scraping then why would it quit and then come back....So...I was thinking that maybe it could be a faulty water pump? But I was thinking, wouldnt there be a significant loss of power if the cylinder was scraping??? I have no loss of power what so ever, just annoying sounds that started randomly. I usually never "gun" my car so it wasnt from driver error. Please let me know. Thanks again.
Old 05-28-2005, 11:47 PM
macder macder is offline
Send a message via MSN to macder
Re: Metal Scraping?
Reading what you've described definetly make me think. Now if all the maintenance/service procedures that you mentioned have been done correctly, then my "Internet diagnosis" would be that maybe your radiator fan is shot, most likely the bearing in it. Run you car while parked with the hood open and try to listen to where the sound(s) are coming from. This looks like it's just another one of those problems that is hard to diagnose unless physically examined
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 05-28-2005, 11:56 PM
Turbodog97's Avatar
Just a Neon
That was the first thing I checked. I first found out that the right radiator fans bolt came off so I put on a new on and then sprayed it down with some wd-40. But I dont think that's it though because the high pitched metallic sound comes on when the fan is off and when it turns on it goes away(at idle) and then the thumping starts(at idle). When driving all you hear is the metallic sound. Kind of scary though, never heard or experienced anything like this before. Thanks again.
Old 05-29-2005, 04:08 PM
Turbodog97's Avatar
Just a Neon
Okay I isolated the area but Im not sure what this part is. It is across from the idle pully closer to the firewall. It is a big bronze colored pully with one of the smaller belts. Im pretty sure that this is making the thumping noise and the metallic noise. Anybody know what this part is? Thanks
Old 05-29-2005, 08:15 PM
Re: Metal Scraping?
If it is down by the bottom of the engine block by the firewall it is most likely your AC compressor.... mine seized up and smoked the belt right off the pully!!! Come to think of it my engine made kinda the same symptoms yours did... kinda forgot about it...does your AC still work? I've heard that with the AC comp. in such a low spot that they shit out somewhat easily...
Old 05-29-2005, 08:55 PM
Turbodog97's Avatar
Just a Neon
Alright awesome, Ya I checked it out and it is the ac compressor. How hard is it to change one of those? Also when it goes out will it affect anything else on the car? Thanks again.
Old 05-29-2005, 09:35 PM
Not a very difficult job but i can be frustrating. Also you probably don't have a recovery tool for your refrigerant meaning you'll increase everyone's chance of skin cancer if you release it into the atmosphere.
Anyways, if you goto a shop they will give you the following quote (Not including recovery and charge)
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 05-29-2005, 10:25 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Damn that is one expensive piece of shit
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 05-30-2005, 01:09 AM
Re: Metal Scraping?
just cut the belt off and call it a day.... it will free up some of the drag on the motor....as for taking the compressor off/out... not too much for weight reduction.... just cut the belt off....
Old 05-30-2005, 08:26 AM
Turbodog97's Avatar
Just a Neon
If I cut off the belt will it take away my air conditioning?
Old 05-30-2005, 08:51 AM
Re: Metal Scraping?
If the belt is not there, then nothing is driving the compressor. I think the rest is self explanatory
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
