Old 05-28-2005, 11:15 AM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
compresion test
hi again guys, today i just ran a compression test a few minutes , and this are the readings , starting from passenger side to driver side, if that helps, my engine is a 420a, 120-110-110-150, so my question is are this numbers to low? i read a post a couple weeks ago about pouring oil in the cylinders, let me know if doing that would help a little, i'd try that later, thanks
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 05-28-2005, 04:24 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: compresion test
Those numbers are low. Is the battery charged? Throttle open? It might suck if those numbers are real.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-28-2005, 05:21 PM
Gsx_hooptie Gsx_hooptie is offline
The compression should be 170-225psi, with the service limit at 100 psi (info specific to 420a). Those numbers do suck. More info can be found at http://www.dsmgrrrl.com/FAQs/compression.htm
A little oil in cylinders with low compression (note: not "pouring" ) will tell you if the low compression is because of bad rings. The above site explains how to do a wet test, if you want to try that. If this isn't the case, you could then do a true leak down test to figure out where the compression problem is.
I doubt the problem is the rings when compression is bad throughout. My guess is mechanical, but that's Kevin teritory. First, make sure your readings are right. See if you followed the procedure on the page I listed, including the things Kevin mentioned. Hopefully that's where the error is
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 05-28-2005, 06:00 PM
thanks for the link, i'll make sure that the battery is fully charged, i'll gladly take it for a hard drive right now, that's what it says in the page, lol.
-MODS-
Old 05-28-2005, 06:49 PM
i just came did another compresion test, and here are the new readings,160-150-145-150 probably the battery,
-MODS-
Old 05-29-2005, 01:14 AM
AF - Advisor
Re: compresion test
A quick note about the "wet test"...
The turbo cars have dished pistons. Not sure if the NTs do, maybe not, since compression is higher. At any rate, using on a dished piston motor is useless. The oil will just sit in the dish, and get no where near the rings. The compression test results will still go up though, because filling the dish with oil makes it smaller Increases static compression ratio.
Good to see the humbers change quite a bit. Unlikely to be a real problem, maybe just battery like you said. If this is cold, a warm motor helps a bit too.
Kevin Jewer
Old 07-28-2005, 01:50 PM
MoozillaGSX's Avatar
MoozillaGSX MoozillaGSX is offline
Send a message via AIM to MoozillaGSX Send a message via Yahoo to MoozillaGSX
Re: compresion test
i looked around but i didnt get ver far, i was woundering if some one could post what a compresion test would look liek on a car thats running good. and then maby on one thats running bad if posible. or if theirs a thread or link or osmehting i didnt see that some one could link me to.
i want to do a compression check soon but it would be nice to have somthing to compare it to when i do it. thanks.
Austin - 95 GSX .
-K&N FIPK.
-Ijnen UICP + Greddy RS BOV.
-Rota Slipstream + yokohoma Es100's.
-Tokico HP Blue's + Springs.
-Power Slot PRO rotors ( slotted+Dimpled ) with Hawk HP Pads.
-Manacore Wires.
( got a 20g and the works in the clothset )
Old 07-28-2005, 03:11 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Re: compresion test
I'm pretty sure 190 across the board, give or take 5 psi, is ideal for our cars.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-28-2005, 04:46 PM
Re: compresion test
kool. also if say 190 is ideal......should they all be at the same PSI ??? what if its like this. 190-185-170-180 ? is that bad ?? or should it be more like 190-185-187-189 "???
Austin - 95 GSX .
-K&N FIPK.
-Manacore Wires.
