Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 05-28-2005, 12:36 AM
3.4grandam 3.4grandam is offline
Question speedometer prob
hey guys im usually on the grand am part of this website but i have a ?about my friends del sol. he has a 93 del sol wit a 1.6 vtec in it. well his speedometer isnt working and his tach if revving wierd. wen he takes off the tach jumps from 4000 to 8000 rpms REAL quick and keeps bouncing around wen he's in higher rpms could this be loose wiring or wut does anyone know?
Old 05-29-2005, 01:21 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: speedometer prob
The harness connector on the back of the cluster could be bad/loose. It's easy to take the cluster out of the Del Sol to look though.
Two screws hold the switch bezel on above the cluster. Unscrew those and pull the bezel off. Then you have one bracket screw to take off at the top of the cluster and four around it. Then just pull it out and disconnect the two connectors behind it.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
