Old 05-27-2005, 09:29 PM
haleyliptz haleyliptz is offline
changed top hose/hole in it since then.....
Got a new radiator hose (top) installed. Everymorning radiator needs coolent, temp shows hot on gage but no overheating, no steam etc.
Now stalling, have to fill everymorning???thermostat you think, not sure where to start now, never had problems until put on new top hose. any ideas....car shopping now.............had system checked for leaks with dye no leaks seen anywhere. however, still dry everymorning, overheats on gage, now stalls. My car ran great until got the hose replaced...any ideas???
Old 05-27-2005, 09:38 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: changed top hose/hole in it since then.....
If it was my car, the first thing I'd try id pull the rad cap off when it's cool. Start it and let it warm up. See if Tstat is opening when warm.
Water has to go someplace. Check oil, see if you have a blown head gasket. If it's not leaking out, it's still in motor.
Good luck
Old 05-28-2005, 12:04 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: changed top hose/hole in it since then.....
Good luck
Nothing worse than a car that has an appetite for antifreeze. I agree with KustomKid 54, its got to be going someplace. Good luck!
Thrasher CAI, DHP v1.0 ECU, Granatelli CAI Tuneable MAF,
3.4 SC pulley, Hi-Flow CAT, u-bend delete, 180 TS,
TB spacer, MSD 8.5mm wires, AC Delco 41-932 spark plugs,
Goodyear Gatorback Serp. & SC Belt
ET: 14.3 @ 96 mph
Timeslip 08/12/06
AF Community Guidelines
