Old 05-27-2005, 10:06 PM
slimredchaos slimredchaos is offline
Unhappy 93 Escort keeps accelerating! Help!
I just moved to California and I took my car into the local smog check garage to get the required check. My 1993 Ford Escort passed fine on idle, but they could not get it to maintain 2500 RPM for the second check. I checked this myself later and found that it was true. When I put my foot lightly on the pedal, the engine slowly revs up and up and never settles. It will go all the way to redline if I hold it long enough. when I release the pedal it hesitates for a second, then drops to idle. I can punch the pedal and it will respond normally, I just cannot get it to hold ANY specific RPM, it just slowly accelerates. If anyone has had this problem, or has any idea how to fix it, your help would be great. I need this to get my car liscenced in California. Thanks.
Old 05-27-2005, 10:41 PM
tturnpaw's Avatar
tturnpaw tturnpaw is offline
Send a message via AIM to tturnpaw Send a message via MSN to tturnpaw
Re: 93 Escort keeps accelerating! Help!
I can almost garantee you its the IAC (Idle air control) sensor. This sits on top of the Throttle body and is held in by 2 bolts and a plug. This costs around $30 at a parts store. Mine had the same issue and this fixed the problem. Its just throwing codes at the ecu thats all.
1982 Mustang GT- roller motor x303 cam, GT40s, MAC/Spintech exhaust MSD ignition, Edelbrock Carb, Ford Racing roller rockers
1994 Escort 2DR LX - cone air, 3.8L throttle body, FUTURE SPI turbo swap
Cops: You can race, but Im impossible to chase!
LS WHAT?
Old 05-28-2005, 01:05 AM
here goes
thanks tturnpaw, ill stop by the parts store tomorrow to try it out. ill keep up with my situation.
