1994 Regal Tranny Shift Problem
I have a 1994 Regal that has 200+ miles. I recently rebuilt the engine. While there we drained the tranny and replaced the filter for the first time. Prior to this we had no problems with the tranny. Now when the engine is cold it has a hard shift going into reverse and drive. After that there is no problems with the shifting. Any ideas?
Re: 1994 Regal Tranny Shift Problem
Make sure the fluid level is correct in the transmission it may be low causing your problem. Also make sure you got the vacuum line to the modulator properly connected if not it can cause hard shifting. If both are ok you may need to remove the pan to insure the filter didn't come loose after you installed it.
i had a imiliar problem with my trann...i ended up buying my car used and i had been sitting on the lot for a while....while the engine would crank fine n all it would refuse to go into gear or when it would when i stopped it would kick out...i took it somplace and hey told me that the seals in the transmision itself were going bad so that might be it...other than that i have no idea
