Old 05-27-2005, 07:15 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Fuel Injectors
I've been looking at some fuel injectors, and am just wondering what the difference between some of them were. There's some listed from 17 lbs/hr flow rating up to 24 lbs/hr flow rating. Considering that I have a 3.4L, what lbs/hr fuel injectors should I go with?
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 05-28-2005, 11:53 PM
blindeyed's Avatar
eBay aDdict™
Re: Fuel Injectors
Come on guys.. seriously, you mean to tell me that out of all the people in this forum, nobody can help me out?
- Jason
Old 05-29-2005, 12:01 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Fuel Injectors
I know my new ones are 42# injectors.
Not sure which ones you need man. Mods?? Just stock injectors?? What are you looking for? Stock replacement?
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 05-29-2005, 03:23 PM
blindeyed's Avatar
eBay aDdict™
Re: Fuel Injectors
Well, I'm trying to get everything I'm going to need for a rebuild. I guess stock injectors would work, but I'm just trying to get as much power as I can from my lil 3.4. So thats why I was wondering what the difference was between the lbs/hr flow rating on fuel injectors.
- Jason
Old 05-29-2005, 03:27 PM
blindeyed's Avatar
eBay aDdict™
Re: Fuel Injectors
btw, this is where I was looking for some fuel injectors
http://www.ftpp.net/V6Main.htm
Just click the "Fuel System" link on the left. You'll see what I mean by what lbs/hr injectors should I go with
- Jason
Old 05-29-2005, 05:04 PM
Mr. Luos's Avatar
Firebird Guy
Re: Fuel Injectors
How much power you plan on making??
You going with boost of any kind?
Stock'ish'
Old 05-29-2005, 10:27 PM
blindeyed's Avatar
eBay aDdict™
Re: Fuel Injectors
Yeah, eventually after I'm done with the rebuild and have more money saved up, I'm going to slap on some twin turbo's.
- Jason
Old 05-29-2005, 11:10 PM
Mr. Luos's Avatar
Firebird Guy
Re: Fuel Injectors
Well, when you boost it, you will need more fuel.
What kinda power you looking to make N/A? 200 wheel? More?
I say get the bigger injectors and make sure you have the car tuned for them.
Stock'ish'
Old 05-29-2005, 11:21 PM
blindeyed's Avatar
eBay aDdict™
Re: Re: Fuel Injectors
Well, I'm wanting to at least hit 250 hp after the turbo's.
And yeah, I was thinking I should go with the bigger injectors as well. And in the mean time I can go with a higher rated fuel pump, and a fuel pressure regulator. That way once I have enough money saved for the turbos, I'll be all set. That sound right to you? Or did I overlook anything (fuelwise)?
- Jason
Old 05-30-2005, 02:26 PM
Mr. Luos's Avatar
Firebird Guy
Re: Fuel Injectors
I am thinking the 24# injectors will probably be too small once you get the turbos. But they should handle anything until then.
Not sure what you will need injector wise once the TT setup is installed.
Are there any boards that are V6 F-Body related?? Hell, maybe even LS1.com or LS1Tech.com might be able to help.
Stock'ish'
Old 05-30-2005, 03:41 PM
blindeyed's Avatar
eBay aDdict™
Yeah, I've tried a dozen times to sign up on FirebirdV6.com, but they never seem to want to approve my account (they have to approve you before you can become a member..). So yeah, I'll check out those other two sites and see what they've gotta say. Thanks alot man.
- Jason
Old 05-30-2005, 04:00 PM
Mr. Luos's Avatar
Firebird Guy
Re: Fuel Injectors
No problem.
Good luck. It sounds like you know where you are going with everything, just need an extra kick. I am that way all the time. Hell, I changed numerous things I was gonna do with this upcoming swap already. One of the few things I did get right was fuel, although I did change my mind on the pump. I bought a Walbro 255, but sold it to upgrade to the Aeromotive A1000. I have 42# injectors, new silver fuel rails, and the Aeromotive regulator. Electric fuel pressure gauge as well.
Also man, check out www.byunspeed.com for parts. Not sure his selection for V6 cars, but his service is badass, shipping is fast, and ALL the pricing includes shipping. I know the sites owner personally. Hell, just watched him install a cam into his SS.
Stock'ish'
Old 05-30-2005, 04:33 PM
Daniel Doerksen's Avatar
Daniel Doerksen Daniel Doerksen is offline
Re: Fuel Injectors
i wish i had efi maybe my next engine??
Old 05-30-2005, 09:23 PM
DarkblueTA's Avatar
DarkblueTA DarkblueTA is offline
Send a message via AIM to DarkblueTA
You can step up to the 24# injectors, but you will need the computer reprogrammed...either buy a chip or re-flashed...not sure depends on the year of your 3.4L.
As far as a turbo kit, depends on the amount of boost you are going to run and how much power you plan on making. I would seriously tell you to get a good fuel system first and then the kit and then have someone put in a good tune before you romp on it.
Good luck
DarkblueTA
GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit
2007 Nissan Titan Daily Driver. 2* advance
