Old 05-27-2005, 04:53 AM
Pvt_Murphy Pvt_Murphy is offline
Olds 403 Torque specs
The other day my 403 blew a connecting rod (out through the oilpan) So now I'm rebuilding my engine with all the preformance parts I was waiting to put in.
I'm replacing the following parts:
Oilpan (Chrome)
Oil Pump (Melling High Volume)
Cranshaft (reground stock)
Main Bearings
Rod Bearings
Connecting Rods (refinished stock)
Pistons & Rings (Clevite 8.5 comp.)
Intake Manifold (Edelbrock 3711)
Camshaft (Melling MTO-1 / Edelbrock 3712)
Pushrods (Comp Cams)
Water neck (Chrome)
Valve Covers (Chrome)
All Gaskets and Bolts (ARP Grade 8 or above)
Once I verify that the engine works fine I'll put on a set of Olds 350 heads '7' casting, do the ignition, rebuild the carb to match, and swap the 350 out for a beefed up one.
Anyway, point being does anyone know the torque specs for the 403 or know where I can get them. Should be the same for the entire Small Block Olds line (260, 307, 350, 403)
I got a base Idea from the Folowing Sites:
http://www.boxwrench.net/specs_index.htm
Chevy and Pontiac specs
http://www.oldsmobility.com/torquespecs.htm
Earlier Oldsmobile Engine specs '64-71
Can anyone confirm any of these figures or tell me the right numbers?
Thanks for your time guys, any help would be greatly appreciated, Gene.
1977 Pontiac Trans Am Olds 403
Rolling like the Bandit!
Old 05-27-2005, 08:58 AM
volkerc's Avatar
volkerc volkerc is offline
Re: Olds 403 Torque specs
Oilpan (Chrome)
Main Bearings
Rod Bearings
Water neck (Chrome)
you could double check with the chilton manuals...
Old 05-27-2005, 09:22 AM
guess I had to buy a manual sooner or later
edit: Haynes is much better
Old 05-27-2005, 01:44 PM
volkerc's Avatar
Smile Re: Re: Olds 403 Torque specs
you might be able to find an open one at a store somewhere....
Old 05-28-2005, 02:51 AM
Well I'll try and find a manual I can list through; maybe I'll just fly it by the seat of my pants like I've been doing.
