Dex_cool only with green antifreeze!!!!!
I had been having some issues with my car slightly over heating. I was checking the coolant jug when i saw a sticker that say to use dex-cool only. but there is green coolant in my car what do i need to do?
2005 Grand Prix GT 3800 1995 Chevy Caprice LT1 5.7 1986 Dodge Ram
Re: Dex_cool only with green antifreeze!!!!!
Both coolents work just fine and despite what others will say will mix just fine. The only problem is that when mixed you WILL lose the extended life properties of dex-Cool. Do you have any idea how long the regular stuff has been in there? If not Id change it to be on the safe side but it depends on you wich coolent you repace it with. They both work, you just have to change the old stuff more often.
BKVic |
you added the dex-cool right?
i have heard of so many problems with it but my car was designed to use it then i should have no problems with it ? thanks
Re: Re: Dex_cool only with green antifreeze!!!!!
Your engine wasnt designed to use dex-cool. Dex-cool just has a different chemical composition to resist the build up of acids for a longer period of time, 5 years or 150,000 miles. Using the old stuff is still completly safe to do as long as you remember to change it at the correct time. You can go to any of the web-sites of anti-freeze makers and they all will say the same. BKVic |
i'm not exactly sure if the 95' aurora's came with standard green coolant or dex-cool...i changed mine to the traditional green antifreeze about two years ago,and have had no problems...i've heard horror stories about dex-cool ???
