Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 05-26-2005, 09:03 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Blow off in neutral?
Ok I'm wondering why my 95 eclipse gsx doesnt release pressure through the blow off valve when in neutral and revving. Is it because the turbo does not wind up in neutral or what? If someone could explain this to me that would be cool.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 05-26-2005, 11:02 PM
cursed1g cursed1g is offline
Banned
Re: Blow off in neutral?
boost doest go up with rmp its how far to the floor the pedal is
Old 05-26-2005, 11:05 PM
Banned
or maybe what i meant was wot is what makes the boost go up enough, no boost pressure , well very little you wont hear it blow off m i personally have dsmlink so i can floor it and it only goes up to 5500 and i get a little blow off action
Old 05-27-2005, 12:14 AM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Im not sure but I think that in neutral, theres not enough pressure. In first gear, youll get more pressure and you should hear a BOV noise.
Also what have you done to your car? If theres no mods whatsoever, your not gonna hear much even when your flooring it down the highway.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 05-27-2005, 12:58 AM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Are you still on the T25? If so you should be able to hear it. When I had my T25 I could neutral boost (maybe a couple psi) and blow off.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 05-27-2005, 01:05 AM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
If u have the 1st gen bov then hit the gas fast til it reach 5500 and release. it should squeel a bit. If u have after market, hit it to 4500 and u can hear the whole thing. Both done in neutral.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 06-01-2005, 02:05 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
you should be pullin 4 to 5 psi in neutral so ya you should hear a faint bov sound
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 06-02-2005, 08:50 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
yeah you should still hear the bov in neutral, depending on what kind it is....if it's aftermarket, your spring could be too tight. but anyway, you're not building up pressure by revving it in neutral because there is no load on the motor. you'll be lucky to see it spike at .5psi MAX in neutral.
