Old 05-26-2005, 06:35 PM
caravan91 caravan91 is offline
squeaks on the turns
hello. i have a 91 dodge caravan that has been giving me some goofy sounds lately. in the past couple weeks it seems to be getting constantly worse. every time i turn a corner with the thing after it warms up, i get a squeaky-squeally sound coming from under the hood. after a few minutes of being warmed up, then the sound becomes constant even while going down a straight road or sitting in idle. everybody tells me that it is probably just a belt, and i have no idea as my car knowledge is relatively limited. i did have the tension belt(i think that is what it is???) fixed on it a couple weeks ago. never made the sounds before the belt was replaced. the vehicle itself is a 91 grand caravan with the standard v6 in it with about 125 k worth of miles on it. anybody have any ideas? please and thank you!!
Old 05-26-2005, 09:25 PM
sandokana sandokana is offline
Re: squeaks on the turns
I would go back to the shop where they changed your belt and double check make sure they used the correct belt and any other parts what they replaced.
Old 05-27-2005, 03:39 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
that sounds like a loose belt to me. have the guy who installed it check the belt tension and make sure it is within manufacturer's specs
Old 05-30-2005, 07:40 PM
vamc's Avatar
vamc vamc is offline
Sounds like the serpatine belt is slipping of the power steering pump.
Old 05-31-2005, 12:50 PM
Allbert Allbert is offline
If you're not already 100% sure it's not the brake wear indicators, I'd check to see if that might be the source of the noise.
Old 05-31-2005, 04:01 PM
evictor evictor is offline
I agree with VAMC it should be your Serpentine Belt. If this is the 3.0l engine with the belt tensioner starts to go the belt has a tendency to jump one grove over on the power steering pully. Replace the tensioner and your problem should be solved. This is an easy job as it only has 1 bolt.
Old 05-31-2005, 09:44 PM
vamc's Avatar
evictor-Thank for backing me up!
