Old 05-26-2005, 06:35 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
rear discs
will 94 teg rear disks fit hatch? not sure if teg is 93 or 94. sticker says 93 but junkyard writng says 94. complete rear discs for $150. good deal?
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 05-26-2005, 08:26 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: rear discs
Yeah they'll fit, either year. Thats an ok deal, your probably going to need atleast new rotors though.
Old 05-26-2005, 08:27 PM
Forunn Daberator
Re: rear discs
by the way, 94 is a completely differnt body style, and you should know the differnce.
Old 05-26-2005, 09:45 PM
Sparsky Sparsky is offline
Re: rear discs
I paid 200 for trailing arms, w/ rotors, calipers, brake cables and 40/40 prop valve. So sounds good to me.
http://www.cardomain.com/memberpage/765867
Old 05-27-2005, 01:35 AM
Jos4DCivic's Avatar
its got ABS. does it matter if i remove relucter ring and sensor? yeah i was planning to replace porpotional valve,rotors and bushing and so forth.
91 Hatch SI
Finally painted!!!
Old 05-27-2005, 02:19 AM
Re: rear discs
Dunno on that one...
Old 05-27-2005, 08:52 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: rear discs
It will not matter, you could even leave them on... if you feel like it, take it to an auto electrican and they can hook it up, so that as the ABS sensor pulses, you could have any light source pulse/strobe with the sensor... could be interesting!
Old 05-27-2005, 05:09 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: rear discs
yeah, or have it hooked up with a black box that translates wheel RPMs into a 12 volt signal that powers someting cool.
i planned on using dodge caravan rear window motors to put power rear windows on my hatch, and then doing the above wiring to make them open at 60MPH
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-28-2005, 02:10 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
Re: Re: rear discs
hope you have a kill switch for when it rains
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 05-28-2005, 05:37 PM
EF You's Avatar
EF Life Giver
Re: rear discs
yeah, im no fool. and im sure theres times when i wouldnt want them to open at all
