What to do?
Hi, I have a 2000 Dodge Neon. I want to make it fast but it seems like nothing is working. So far I have added an Short ram intake, OBX header and down pipe, 2.25" exhaust pipes, straight through muffler, under drive pulley, 7.5mm plug wires, NGK Spark plugs,160 degree thermostat, and Upgraded coil pack. It is an 3 speed auto.(which sucks) Here are the Stats
Best: 60 Feet 2.608 1/8 mile 11.536 MPH 62.56 1/4 mile 17.776 MPH 78.48 That was even power braking at 2500rpms For those that don't know what "power braking" is its when you hold the brake pedal down hard as you can, and give it so gas to rev it up at the same time. I don't know if this is normal or if its my car. What can I do to make it faster?(besides transmission/engine swap, or a turbo) I would like to get a new car but this car is paid off already, and plus I don't have that much money since i'm going to college. So please give me some ideas. Thanks |
Realistically there isnt going to be much you can do to make it fast. You started with a not so fast car....... You could go f/i........ or maybe some nitrous..... How fast do you want to pay?
Re: What to do?
Well unfortunately you are going to be stuck with a slow car, unless you do some major mods. Mods like cam, cam gear, a real cold air intake, not the short ram, bigger pistons, and so on if you just want bolt-ons. The best way to get quicker is to do what you said you didn't want to do, ATX->MTX swap. It really isn't that difficult to do and can probably be done for less that $500 if you do it yourself. But for an extra $250 you can start spraying w/nitrous.
Re: Re: What to do?
If you are talking HP, it depends on what other mods you are running. The cam can add, let's say between 5-15 HP. Again though it depends on what other mods you are running. Keep in mind, if you upgrade your cam, then you will have to upgrade your valve springs also.
Well I want to put a SRT-4 engine in my car but I don't know if it will fit. When I looked at my friend's SRT-4 the motor mounts look like they are in the same place. But there is more to it like changeing my auto to an manual, Fuel pump, and maybe new axles. It sounds like it would be cheaper to put an SRT-4 engine in then to get another car.
I am still thinking about putting ported heads with cams in but if I do that it will be pointless once I do put the SRT-4 engine in. Does anyone know how much this will cost or can the SRT-4 engine even fit? |
Re: What to do?
I recently installed new. piston rings rod bearings intake valves cane 158-0010 camshaft bush platinum 4 spark plugs my car doesnt 'feel' got much power after that actually it feels the same than before when I only had intake and muffler. |
Re: What to do?
You need to take out the #10 cam, and put in a #14 cam. The #10 won't do much, but the #14 will after tuning it w/a dyno. As far as the other things, you put on, none will yield any additional HP. You're car should run better, but you didn't add any HP mods. One more thing, lose the platinum plugs and go with the stock champions. The neon doesn't benefit at all from the added sprak.
Re: What to do?
thanks
Re: What to do?
