Old 05-26-2005, 12:58 PM
vegasgirl's Avatar
vegasgirl vegasgirl is offline
Question NEED Answer to the **Ultimate Key Question**
I think this needs to be a sticky thread...
I know that many of us have had the "key stuck in ignition" issue.
Mine has been in there for about a year!
I had a key made from the VIN of my car and use that to get in. I am soooooo tired of it.
So, I want to start at the Least expensive fixing option and go from there.
I have seen many answers, but dont know where to start.
Can someone, or everyone, imput their answers here?
How do I get to the key release button?
Where would I put the bolt if I needed to put on in there?
Why does it cost $500 to replace the soloniod?
Thanks! You are all so helpful!!!
Old 05-26-2005, 01:25 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: NEED Answer to the **Ultimate Key Question**
OK, cheapest. If it's a 1997 or newer.
Look under where key goes. You will see a rubber plug. Remove it. Take a pencil and stick it in. You will feel (with key in "on" like you are pushing a plate in. Turn key off, take out key.
If you don't get this fixed soon, find something better then pencil to use. Lead will end up braking off in there. And that sucks.
Old 05-26-2005, 01:28 PM
I'm sorry. It cost $500.00 because it's a damn dealer. I wouldn't put a bolt in anywhere.
I think that's all you asked.
Old 05-26-2005, 04:25 PM
ericvrose ericvrose is offline
Where in Vegas are you? I'm here too and I'll help you if you want.
Old 05-26-2005, 04:43 PM
We may have our first date on this site. Keep us informed.
Old 05-26-2005, 05:58 PM
vegasgirl's Avatar
Thanks for the offer. I am in Green Valley. Have you had that problem too?
Old 05-26-2005, 05:59 PM
vegasgirl's Avatar
Re: Re: NEED Answer to the **Ultimate Key Question**
Well, he would have to talk to my husband about that first
Old 05-26-2005, 06:00 PM
My wife would'nt mind me helping another GPer but I dont think she would approve of dating one.
Old 05-26-2005, 06:03 PM
OK guys. I was only kidding.
Old 05-26-2005, 06:04 PM
I'm at Flamingo and Durango 6 miles from the strip.
I had the key stuck problem two times. One was a dead battery. The other was when I replaced my shift knob and had to do some adjusting cause it wasnt going all the way into park. Everything works now.
Old 05-27-2005, 07:46 AM
mkrazy1 mkrazy1 is offline
I am having the same problem (on 97 GTP), along with not being able to get it out of park unless I use the emergency release button. I replaced the brake switch since it was only about $20 but that wasn't the problem either.
I was told it is most likely the lock cylinder (which I really doubt) but I can't figure out how to remove the old one. Anyone know how?
I removed the plastic shield under the steering column and removed the wire going to the lock solenoid and I'm only getting 4 volts there. It should be 12. The same thing with the shift lock solenoid. Does anyone have any ideas on what the problem is, or how to further check it out? Anyone have a wiring diagram showing this circuit? Help!!!!
I did find this posting, which explains how to remove the lock cylinder - woo hoo - http://www.automotiveforums.com/vbul...ss#post2279687
This posting also leads me to believe the problem may very well be the ignition switch, not the ignition cylinder. Anybody have the wiring diagram for the switch, or can tell me how to test this???
Old 05-27-2005, 01:36 PM
vegasgirl's Avatar
Hey it was a good try!
Old 05-27-2005, 01:42 PM
vegasgirl's Avatar
I have an automatic...not sure it that makes a difference.
We are working on getting the steering cover off, but I did not have the tools. I am scared to do that, though.
I locked my key in the car this morning! I am just so over it.
Ericvrose, I will PM you...
Old 06-07-2005, 08:11 AM
Just as an update. I replaced the ignition switch and that was the whole problem.
Old 06-07-2005, 09:52 AM
GTPWarrior's Avatar
GTPWarrior GTPWarrior is offline
What an ass
[b]1998 Pontiac Grand Prix GTP
"A man walks into a bar and says.....................*ouch*"[/b]
