Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-26-2005, 12:06 PM
JordansLude JordansLude is offline
Engine...Weirding out, Help please
Okay when i start my car everything is good but occasionally the idle revs to 1k and then shakes and drops down to zero and the car shuts off , the when i try to start it again it wont turn over it just keeps making the car starting noise. Im getting a tune up soon so hopefully that will solve that problem. And another thing when i Move my car from Park to reverse or drive i can here like a clanking sound coming from the right front tire and it jerks hard, and the engine shakes .....not violently but enough to be noticed . when i drive the car i can here like a rattling sound coming from that tire and the other tire somtimes and if i were to hit like a little crater in the road the car swerves alittle , i think its a bad shock because when i hit a small crater you can here it like a thud /bottom out sound , if anyone can help me it would be greatly appriciated
Old 05-26-2005, 12:24 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Engine...Weirding out, Help please
could be a strut, could be a balljoint, could be an axle... as far as the engine probs go, a tune up should fix it.
Old 05-29-2005, 12:14 AM
crazzysol crazzysol is offline
Re: Re: Engine...Weirding out, Help please
try replacing the main fuel relay.when it goes bad it cuts the fuel pump off.as far as the noise motor mount or suspention prob. check out all of your bushings,endlinks,ball joints, axles.
