Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 05-26-2005, 11:37 AM
blastnick blastnick is offline
cutlass supreme want turn over
I have a 1992 cutlass supreme and the head gaskets leaked so i put some stop leak in there to stop the leak. Well, I was going to the store and it cut off on me in the middle of the road. IT would crank but would not turn over. I had a shade tree come look at it and he said the fuel pump was good and it was not the timing and it had plenty of water. I am at a lost. He did say something about the fuses might be bad or something electric. Should i put new fuses in or has wire or plug disconnected or is it the head gaskets. Can some one give me a direction to go in, please.
Old 05-28-2005, 10:53 AM
Stormysdad Stormysdad is offline
Re: cutlass supreme want turn over
"...cranks but would not turn over..." sounds like starter not engaging flywheel. Is that true? or do you mean turns over but won't start??? Check ALL your fuses, fusible links and compression. Cut off in the middle of the road sounds like electrical.
Old 05-30-2005, 06:19 PM
Yogi442 Yogi442 is offline
ignition module located under the rotor on your distributor. This is very common. When the module blows it generally gives no warning and shuts motor off. It is your spark source so no juice gets to your plugs. Not hard to replace and runs about $50.00 to $65.00.
