Go Back   Automotive Forums Car Chat > Buick > Regal
Old 05-26-2005, 09:10 AM
interested interested is offline
dash lights gone crazy
I have an '01 Regal that while I am driving the dash lights will flash then the needle gauges all go to the zero postion also the ringers chime. Any hints to as what this problem could be?????
Old 05-26-2005, 06:34 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: dash lights gone crazy
The BCM (body control module) is probably going bad and needs replaced. Before changing it though check to make sure the connections are good. Sometimes they get dirty or come loose due to vibration. I am not sure where it is located on the Regal.
Old 05-26-2005, 09:10 PM
Re: Re: dash lights gone crazy
Thank You I will check it out.
Old 05-26-2005, 11:35 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: Re: dash lights gone crazy
The Body Control Module (BCM) for 1997 and up Buick Regal LS or GS and Century is located under the driver's side dashboard right next to the parking brake. It mounts vertically and the connectors are located on the bottom for access. Its the first module (big). The smaller one to the back is the Daytime Running Light (DRL) module.
To access it remove the felt covered kick panel (two retaining push on plastic clips) and drop down the panel. Look up and to the left, can't miss it.
Here is a representative view of a GM BCM:
Timeslip 08/12/06
AF Community Guidelines
