Old 05-25-2005, 11:37 PM
irupp33's Avatar
irupp33 irupp33 is offline
Send a message via AIM to irupp33
Boost leak test?
Ok my car feels fine in 1st then i hit second and it feels like i have a major boost leak. Now i built a tester via vfaq.com but i found this other web site that had some bs about opening the TB and T'ing a vac line on the BCS and some other stuff. I thought you can just pull off the intake from the turbo and bolt the tester up and connect your air supply. Am i wrong? Is there a certain way u have to do it?
Old 05-25-2005, 11:49 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: Boost leak test?
Thats how i read ur supposed to do it, that way u listen/feel for air leaking, hence boost leak....vfaq.com is usually right about most things. I think I saw someone on the board doing it ur way though
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 05-26-2005, 12:06 AM
Gsx_hooptie Gsx_hooptie is offline
First, hook it up to the turbo. Then, if things seem funny, try hooking it up to the TB. There are quite a few seals that can wear out there, and if you're not sure where the leak it, that's a good place to test independantly by hooking up to it directly.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 05-26-2005, 01:37 PM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
They have a boost leaker test on ebay cheap....or you can save yourself a few dollars and buy the parts yourself....I have actually seen how to build somewhere around this place we call the internet. Try doing a google search
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 05-26-2005, 03:12 PM
kjewer1 kjewer1 is offline
AF - Advisor
The vfaq one is fine. If you do tap into a vac line or something, you still have to pull the intake and cap off the turbo so all the air doesnt just leak out there. The air wont go through the motor, since the intake or exhaust valves will be closed on each cylinder.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
