Old 05-25-2005, 10:34 PM
irupp33's Avatar
irupp33 irupp33 is offline
Send a message via AIM to irupp33
Injector cleaning?
Hey guys i have a 92 talon Tsi and i noticed when Im in high rpms in 3rd gear its feels like it not getting enough fuel (kinda sputters) I know its not fuel cut and i just replaced the plugs (ngks) and the wires (hotwires) and a buddy of mine said it might be dirty injectors. How do you clean em out. Does that crap that comes in a bottle that u add to your gas tank do it or do i need to take em out and do it? Thanks for the help.
Old 05-25-2005, 10:52 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: Injector cleaning?
I used injector cleaner that you put in your gas....seemed to work fine.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Lucas injector cleaners
....It has been a LONG time...I want to move to FL or Japan.....
Old 05-25-2005, 11:44 PM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
You could send them to cruzin performance. They do a bang up job of cleaning and flow testing them.
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
Old 05-26-2005, 02:20 PM
kjewer1 kjewer1 is offline
AF - Advisor
The in the tank stuff is more of a preventative measure. If they are actually clogged, it wont help much. IF you do use those things, at least run the tank down to a quarter or so, so its more concentrated. I personally run some MMO (marvels mystery oil) through every so often. Its an awesome cleaner. I also add a quart to the oil a few hundred miles before its due for an oil/filter change.
The best way to make sure the injectors are both clean, and flowing what they are supposed to, is to send them out to cruisin as mentioned above, or another similar injector shop.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-26-2005, 02:35 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
I recommend Lucas also...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
