Old 05-25-2005, 10:20 PM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
B18 Swap Not Running Right! Need Help!!!!
Ok its been about a week and i really cant stand it now.
I have an 89 civic with 94 integra B18 engine swap.
When the throttle is at a certain point it chugs badly. At 65MPH and lower it wont stay at an idle speed it is either accelerating or decellerationg. I have changed mutliple sensors like the IAC sensor and nothing has worked. What else could it be?
At 75 MPH and higher it drives fine and i can go one speed.
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 05-26-2005, 01:24 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Re: B18 Swap Not Running Right! Need Help!!!!
Might be the distributor. I've had similar issues, and it was the distributor.
Does it accelerate and decelerate fine? It only does it when your trying to stay idle? If so I think it might be a timing issue. Check that also.
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 05-26-2005, 09:56 PM
yea it accelerates and deaccelerates fine but when i try to just go one speed it baugs down and sputters.
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-27-2005, 02:05 AM
quiXilver's Avatar
I wouldn't do anything untill I check the timing. My car did the same thing and my timing was off.
B18A
Old 05-27-2005, 09:12 PM
is that the engine timing with the cams or the Ignition timing with the dist.
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 05-28-2005, 08:38 AM
quiXilver's Avatar
I would check both, but ignition first. If no results, then try the cam timing.
B18A
Old 05-29-2005, 11:33 AM
Ok thanks dude, i guess i got some work to do!
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
