Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 05-25-2005, 10:17 PM
carnut04 carnut04 is offline
Twin Turbo
I was wondering if a twin turbo kit like this one http://www.bankspower.com/twin-turbo-system.cfm would work for a 79 chevy small block non-fuel injected V8 engine? ALso would this kit be more costly than buying a new crate engine?
Thanks
Old 05-26-2005, 06:38 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: Twin Turbo
I think they had a system for a carbed engine, they talk a bit about it on their site. you should try looking for one of those on ebay or something and try calling them. I think a new crate engine is pretty expensive, i think the cheapest i saw was $5500. if you find a setup for your carbed car, go for it, it would make your car more unique than throwing in a crate engine, or you could get the crate engine (hopefully fuel injected) or install a fuel injection system on your car then throw a turbo kit on. you will probably have better luck and an easier time if you install a supercharger, if you go this route, i would suggest centrifugal supercharger (you can get one from paxton or vortech superchargers) because they're more efficient than positive displacement superchargers and produce more turbo-like power. Hope i answered your question.
Old 05-26-2005, 08:38 PM
Thanks for the reply
Old 09-19-2005, 09:24 PM
gmdt350 gmdt350 is offline
been there done that
hey man i'v actually got a 79 chev 1/2 with a small block chevy twin turbo. runs 12 sec in the 1/4 mile. its very easy to do. i am pretty much the only guy that anyone has seen doo it by the sounds of it. i'v been having so much fun with it i figured y not share with you what i did. its basically a stock 350 i found 2 slightly used trubos from older 6.5 L gm deisel engines from there i mounted them on a flange from the inner fender well one on each side then made a box with 2 inlet ports out of aluminum that bolted on the carb. then just run tubing to the turbo from the carb. for the exhaust i had an older set of headman headers which are basically mount backwards and upside down modified them slightly and welded on a flange then bolts to the turbo. then run exhaust pipe down out of the turbo into ur mufflers. then use the oil outlet for ur oil pressure sending unit t the line one to each turbo and have a line that returns oil back to the oil pan. then i just have a cone type air filter on each turbo. i have had it built and it works amazing the other thing u don't wanna forget is dump valves to limit the amount of boost i'm running 6 lbs from each turbo is nice tame truck to drive on the streets and it still pulls hard and its only a minor adjustment if u want more boost. my engine has 85 000 kms on it and it still runs and performs as well as the day i got it running well good luck and hopefully u get it all figured out
Old 09-19-2005, 09:33 PM
