Old 05-25-2005, 09:21 PM
89si's Avatar
89si 89si is offline
how do you remove driver side window trim? (metal black pieces outside)
well now that i have my sub in my car, i pretty much found out what screws were loose. one that i need help getting at is under the black trim pieces that go over the edges of the windows where the door opens.. hopefully you know what i mean.
they go vertically along the glass and have 2 screws on the side. i have popped off those 2 screws, but i want to take off the one trim piece to get at a screw that is underneath it, cuz it squeaks a whole bunch because it has come loose: allowing some movement along the screw..
i dont know if i made any sense, so please ask if you need clarification. i'd really like to get this tightened up today cuz the squeaking and rattling behind my head is driving me nuts.
89si-
78000kms on original engine.
sub is in.. lights are just about done..
Old 05-25-2005, 09:46 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: how do you remove driver side window trim? (metal black pieces outside)
the one for the back side glass has two screws on it, and then snaps off. under it is two hinges for the glass.
the other one, on the door, has two screws in it, and some sticky substance, along with clips. after you take the screws out, push it upwards and pry it off. its kinda tough if the sticky stuff is holding tight.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-26-2005, 01:42 PM
89si's Avatar
ok, well im going for the rear one. i have those 2 screws off of it so that it can slide up and down, but i dont know how to pop the piece off of the glass.
89si-
Old 05-27-2005, 12:54 AM
89si's Avatar
ok actually i just kinda yanked on em till they came off and it worked alright, thanks for the info anyway. i broke my damn screw driver tightening the screws that were being shaken loose, what a piece of shit. o well. no more squeaking anymore!!
man i love how the sub turns heads.. lol.
89si-
Old 05-27-2005, 07:45 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
You'll love it even more, when your car starts rattling and squeaking again from the bass...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 05-28-2005, 12:20 AM
89si's Avatar
meh, it happens, i take care of it. and the pieces i said were metal i found to actually be plastic, my bad.
89si-
