Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon
Old 05-25-2005, 09:34 PM   #1
conspiracy
potential
Im new to dodges and i just bought a 03 neon se yesterday, my question is does this car have the ability to make any power cuz right now im not impressed, I was stupid and got the first car i could afford with cash cuz the guy at the dealership said i couldent get a cheeseburger with my credit. its a lousy automatic by the way,
and also if any 1 knows the hp and trq specs on it?
conspiracy is offline   Reply With Quote
Old 05-25-2005, 09:50 PM   #2
TEXSRT4
Re: potential
i smell an SRT4 swap. it will bolt right in, and double the power you have in that SE. it will work with your tranny too. just get the complete motor with intercooler, and computer. plug it in and your done.
TEXSRT4 is offline   Reply With Quote
Old 05-25-2005, 11:24 PM   #3
conspiracy
Re: potential
with the srt4 thats a manuel i understand so running the ecu for the engine will work for the auto?
Old 05-25-2005, 11:27 PM   #4
conspiracy
Re: potential
Tex and also do u know any sites where i can research the swap and maybe find an engine??
Old 05-26-2005, 12:37 AM   #5
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Here you go to learn all about your new ride.
http://www.neons.org/faq/2kfaq/
das2123 is offline   Reply With Quote
Old 05-26-2005, 01:44 AM   #6
TEXSRT4
Re: potential
the swap is easy, but i dont know about a site that has that information readily available. try to do a search on srtforums.com, one or 2 guys there have base model neons with sartie powerplants. or get ahold of darrel cox racing. he builds top notch neons. he can give you directions.
overall, though, the install is cake. the motor is the same external block, so everything bolts together nicely. the computer is in the same place, so it plugs in nicely. if you want to keep your auto tranny though, you will have to keep your stock computer and get a fuel/air controller or piggy back computer to control everything.
Old 05-26-2005, 10:20 AM   #7
skatendestroy
Send a message via AIM to skatendestroy
Re: potential
What about the sentry key though that the srt uses though...
skatendestroy is offline   Reply With Quote
Old 05-26-2005, 11:03 AM   #8
das2123
Re: Re: potential
NEONS
The best neon site on the web.
Old 05-26-2005, 09:41 PM   #9
TEXSRT4
Re: potential
the sentry key is only required if you are using the stock srt computer. if you want to keep your auto tranny, you will have to use your factory computer and a fuel/air controler. in which case you dont need it to worry about the key. if you do want to swap to a manual tranny, just get the stage 1/2/3 computer upgrade and you dont need the key
Old 05-28-2005, 12:49 PM   #10
conspiracy
Re: potential
cool alot of useful info but i got a problem with my car now the damn thing wouldnt shift out of first the other day. out of no where the engine light came on the mph gauge went wack and the tranny wouldnt shift. i checked the fluids and were fine im guessin maybe the the throttle cable for the passing gear, or the shift linkage itself.
Old 05-28-2005, 12:52 PM   #11
conspiracy
Re: potential
also could the tranny shifts be controlled by the computer? anyways monday im taking the piece to the dealership to fix it so ill see then
