Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 05-25-2005, 08:21 PM
86lude 86lude is offline
idle problem with 86 si
hi guys, ive been reviewing the boards for over an hour and decided to post, i have a 86 lude 2.0 si and i have a rough idle problem, the idle will go to about 2250 and drop to 1750 rev and drop rev and drop, now the wierd thing is the idle will settle once the fan kicks in, once the fan stops the idle problem continues once again, any help would be awsome. ive heard things like, coolent temprature sensor, egr valve, idle air control valve, coolent levels, someone please help =] i cant stand the rough idle anymore and i know there is prolly someone here who has delt with the same problem, i love my lude and i donnt want to give it up from a rough idle problem.
Old 05-27-2005, 11:28 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Re: idle problem with 86 si
Check all of your vacuum hoses (any hose that doesn't run coolant or oil). The idle system, among other things, is controlled by air vacuum. Then again it could be any of the above that you mentioned too. Hope you find it!
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 06-02-2005, 04:28 PM
hondaprelude88 hondaprelude88 is offline
You might bleed the coolent sounds funny but try it there should be a bleeder valve on the thermostat houseing. Start the car open the valve and leave it open untill the coolent comes out in a stream. works best with the front of the car up so the air moves forward remove the rad cap and leave open and add coolent as needed.
Old 10-09-2005, 06:58 PM
curlz500 curlz500 is offline
I had the same problem last year and it was really embarassing to drive. It moslty only happend in the cold when my car was warming up. All i did was change my thermostate and the the prob went away. Give that a try because its cheap enough that if it doesnt work you wont be loosing any money
Old 10-09-2005, 11:46 PM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Your about 4 months late on this one.
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
