Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-25-2005, 07:40 PM
Jdbaldwin86's Avatar
Jdbaldwin86 Jdbaldwin86 is offline
Send a message via AIM to Jdbaldwin86
Head Gasket
Ok guys, i just bought my 95 Eclipse GS with 103k Miles on it. I notice the next day that it is leaking oil...i take it into O'Brien Mitsubishi and have it checked and they tell me that the Head Gasket is leaking oil, and it will cost me about a grand to fix. My question is Should i buy a head gasket / timing belt now on ebay and just pay for someone to install it, wouldnt it be alot cheaper, Also they said i need a new clutch, it obviously isnt the way to go to buy from a dealership is it? The cost to fix everything i needed fixed from them was over 2700 dollars without the timing belt. It included the Head Gasket, Rear Right Shock, Clutch, and Gas Gauge.....He told me the clutch for a 95 eclipse is going to run me about 550 bucks with the flywheel, yet i see one on ebay right now for 200 bucks with the flywheel, is LuK a good brand? A cylinderhead gasket = just a head gasket correct? I know i sound like a complete idiot, but like i said i just bought my first eclipse and i love it and dont wanna let it go... but if i cant fix it for alot cheaper then 2700 dollars i cant keep it. THANKS TO ANYONE WHO HELPS ME OUT!
Old 05-25-2005, 07:55 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
Re: Head Gasket
If you know someone (shop) who can set timing and has good tools, It would cost you less than half the cost of the dealer to fix. Let me get some more info. ans I will try to keep you posted. As would everybody else.
....It has been a LONG time...I want to move to FL or Japan.....
Old 05-25-2005, 11:31 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Head Gasket
also you'll probably want the whole cylinder head kit, just not the headgasket itself. then you'll get new intake, exhaust mani gaskets, valve cover gaskets, head gasket, miscellaneous stuff. also you'll need to get new head bolts if you replace the head gasket.
alot of times, dealers look for stuff that could maybe possibly have the slightest chance of going bad in the next 2-3 years. i wouldn't replace it unless it's broke. if your clutch still works properly and shifts fine, don't replace it. dealers will rip you a new one on shit like this. take it to a reputable shop and have the stuff done, it'll be cheaper. i wouldn't recommend putting on anything other than OEM though for gaskets, they don't seem to last as long.
95 Talon TSI AWD
97 Eclipse GST
Old 05-26-2005, 02:06 AM
ok, well.... i have a cold air intake on my car at the moment, you saying i should replace that? and how much is the other stuff i would have to replace along with the head gasket / header bolts?
Old 05-26-2005, 03:16 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Head Gasket
arp head fasteners are about $80. gasket set is about $189, unless you go with cometic. mitus gaskets are prime for you, but topline also offers a great gasket kit of about $30 less.
DSM geek
Old 05-26-2005, 04:06 PM
just bought cylinderhead gasket, full set of head bolts, and timing belt for 110 dollars off of ebay, un used...So now i have to buy side parts for fixing the head gasket? By the way think i should just put the timing belt on when i get the head gasket fixed? And what else do you guys think i should fix while im at it?
Old 05-26-2005, 04:23 PM
drewh4386's Avatar
Re: Head Gasket
just about everything he said above. And about the timing belt, do it then because it will save you from having to get it done later. It may also save you a bit more money.
Old 05-26-2005, 06:09 PM
Ok so far to fix the car up i have -
Cylinder Head Gasket
Timing Belt
Header Bolts
can someone please list the things i need to look up on ebay, or call about in their exact names people would post / sell them as hehe, sorry for my car incompitance.
Old 05-27-2005, 02:02 AM
Re: Head Gasket
-cylinder head gaskets KIT (includes head gasket, exhaust and intake manifold gaskets, valve cover gaskets, thermostat housing gasket, etc gaskets)
-cylinder head bolts (not header bolts) preferrably arp
-timing belt.
-thermostat
-1.2 gallons mixed 50/50 antifreeze
might as well do a damn tune-up while ya got it apart.
-5 quarts oil
-1 oil filter
-spark plugs
-fuel filter (do this while the head is off, it'll be 100x easier)
-clean the air filter
95 Talon TSI AWD
97 Eclipse GST
Old 05-27-2005, 06:49 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Head Gasket
Also to add to gthompson97's list. Balancer belt, tensioner and water pump (goes along with the timing belt)
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 05-27-2005, 05:30 PM
so the current cylinderhead gasket / header bolts that i bought are pointless because i need to buy a head gasket KIT?
Old 05-29-2005, 01:40 PM
Re: Head Gasket
bump~?
