Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 05-25-2005, 06:17 PM
Olona Olona is offline
Unhappy Battery Drains
86 TBird drains battery. New battery, new alternator, battery continues to drain. Anyone have an idea?
Old 05-26-2005, 04:12 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Battery Drains
You have something that is staying on all of the time. A trunk light or hood light staying on are good possiblilities. With the key off connect an ammeter between the positive cable and the positive battery terminal to check for current draw. While watching the meter, remove fuses one at a time until you find the circuit that is drawing current.
Old 05-26-2005, 06:28 PM
Re: Re: Battery Drains
I assum you remove the positive batt cable to do this test? Also thank you very much, I never thought of that, that is brilliant.
Old 05-26-2005, 07:37 PM
97Bird's Avatar
Re: Battery Drains
Remove the negative cable FIRST and then the positive cable (to prevent sparks!) then connect the ammeter neg (common) lead to the positive cable and the ammeter positve lead to the battery positive terminal. After that, reconnect the negative cable to the battery and check the current.
Old 05-26-2005, 10:25 PM
Re: Battery Drains
Thank you so much have a good weekend.
Old 05-27-2005, 06:11 PM
97Bird's Avatar
Re: Battery Drains
You're welcome and good luck!
