Old 05-25-2005, 06:29 PM
KMoney28 KMoney28 is offline
Send a message via AIM to KMoney28
XXX Wiring Question
Sometime this week I plan on ordering two XXX12's. I will either be running them of this Autotek amp:
http://audiodiscounters.com/sitemap/...t_id/2173.html
or this Orion 2500d amp:
http://www.orioncaraudio.com/amps/Dmono.asp
My question is what voice coil configuration should I get when I order them? I believe the choices are dual 2, dual 1, or quad 2. I wanna run it to the point where the subs are almost fully powered to their potential but I don't want to blow the amp(as I have always been skeptical about running anything at 1 ohm).
Sub: 1 15" Digital Designs 9500 in a slot ported box with 6 cubes
Sub Amp: Autotek MX-3000.1
Component Amp: 300 watt Pioneer
Headunit: Alpine CDA-9831
Speakers: 5.25 Sony's and 6x9 Pioneer's(Both of which need to be replaced so give me some suggestions)
Optima Yellowtop battery
Lanzar 5 farad Optifree capacitor
Old 05-25-2005, 06:46 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: XXX Wiring Question
Depends on what amp your going to use, pick one.
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 05-25-2005, 07:16 PM
which do you recommend? Or are there any others...I'm lookin to spend less than $600...I can get the Orion for $600 and already have the Autotek...what else should I consider? Keep in mind that if I get a new amp it won't be for at least a month, so I'll have to temporarily run it off of the Autotek, which brings up the voice coil and wiring issue again.
Old 05-25-2005, 07:23 PM
Mannyb18b's Avatar
You can use the autotek, you just gotta tone it down a bunch. Those subs only need 250watts really. (2) Atlas 12's can be wired in a 8ohm load, wich will work good for your amp.
Alpine H/U-
CDT EF-61's
NSB-100
Old 05-25-2005, 09:42 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
WTF are u smokin Manny he said xxx 12's not fuckin atlas 12's..... lol ..... keep the autotek (badass amp) get stock xxx's (dual2) wire in series parallel and your good to go.... for the box build it 4-4.5 cubes net to the desired tuning freq.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 05-25-2005, 11:35 PM
Re: Re: XXX Wiring Question
Yea I have around 6 cubes total...I was thinkin about tuning it to 32hz would that be straight? Also, if I keep my amp and wire it how you said, what ohm load would it be running at and how much rms would each sub be getting?
Old 05-26-2005, 12:12 AM
3000 1500 per sub @ 2 ohms...... and the amps prolly underrated..... 32 hz is perfect..... hit me up if u need box designs.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 05-26-2005, 12:05 PM
ngsm13's Avatar
ngsm13 ngsm13 is offline
Send a message via AIM to ngsm13
Yup, the two subs will present the amp a 2ohm load. Therefore "3000watts" to the pair. Either Mike or Myself can design you custom enclosures, with everything you need including a cutsheet. peace
NG
I design custom enclosures!
And...my sig is short!
Oh and.. YOU suck balls...
Old 05-26-2005, 06:23 PM
Re: Re: Re: XXX Wiring Question
NG
Hmm, well now I don't know who to choose....
Old 05-26-2005, 06:34 PM
ngsm13's Avatar
Re: Re: Re: Re: XXX Wiring Question
I have a better design program than Mike
NG
Old 05-26-2005, 10:48 PM
Choose Noah and tell him he has to use half the money to pay off the debt i owe him.
D31 yellow top
Kenwood DDX-7017
Orion 275SX (Mids)
Old 05-27-2005, 04:16 PM
Mannyb18b's Avatar
wtf was i smokin....
Alpine H/U-
CDT EF-61's
NSB-100
Old 05-27-2005, 05:07 PM
I called today for pricing and the XXX is $405 shipped to Chicago which is cheaper than I thought it would be, so I'm going to order it sometime this weekend. So...I should order dual 2's right guys? I'm just askin again because the specs for the Autotek amp confuse me...I want to be absolutely sure before I order the subs that the amp puts out enough power...at 2 ohms is it 1200rms or 1500rms?
You guys can also hit me up on AIM at Jiggaman28 and let me know how the whole box plans thing goes. How many people here actually do it, and who does it the best??? How about you Sr20??
Old 05-27-2005, 06:55 PM
Here are better specs of the amp I think:
http://www.onlinecarstereo.com/CarAu...roductID=13933
