Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 05-25-2005, 10:24 AM
Huntersmom Huntersmom is offline
Question Power slider won't lock/unlock by electrical sources
I have a 2001 Venture and the power sliding door will not lock or unlock using either of the power/electric options. It will not work with the keyfob or the switch on either front door which is to lock/unlock all doors. The only way I can lock and unlock it is manually sliding the lever on the door. Please help!!!! Is this a connection issue, motor issue, fuse issue?? Any suggestions would be greatly appreciated. Thanks!
Old 05-25-2005, 12:44 PM
parts_guy parts_guy is offline
Have you tried cleaning the electrical connections between the door and the door frame? There is a pad of about 6 brass looking plates on the frame and there are 6 corresponding spring loaded connectors on the door. Try cleaning them with a scoth-brite type pad to create a good connection. I have done this a couple of times on my 2001 Venture and it clears it right up..
Old 05-25-2005, 12:52 PM
cdru's Avatar
cdru cdru is offline
Re: Power slider won't lock/unlock by electrical sources
I have heard a pencil eraser will also clean them. It's not as abrasive, but it also won't do as much if they are in really bad condition.
Old 05-25-2005, 03:55 PM
Thank you so much for the advise, however, I just used a scotch-brite pad and clean both sides. This doesn't help. Is there possibly a wiring issue?? A wire that has disconnected or erroded?? I have read other threads where they were having power sliding door problems and it was relate to wiring. Thanks!
Old 05-25-2005, 03:57 PM
Re: Re: Power slider won't lock/unlock by electrical sources
Thank you for your suggestion. Cleaning the connections didn't help. Please see my response below.... are you aware of any wiring problems that could cause this?? Thanks!
Old 05-25-2005, 10:57 PM
cdru's Avatar
The power sliding door opening/closing is controled by the BCM. Occasionally it gets confused and the buttons don't operate the open/close functionality until it has been reprogrammed. I don't beleive this is the same as your problem though as you are having problems with the locking only, correct?
I would round up a wiring diagram and a multimeter and start poking around. See if the connectors ever get a voltage. If they do, then you know it's something within the door. If they don't, tracing it back to figure out where the problem is at.
Old 05-27-2005, 12:30 AM
GregA's Avatar
GregA GregA is offline
I found a wiring diagram for the power locks you can view here:
Power Door Locks
Good Luck,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 05-27-2005, 08:40 AM
Thank you for the information. I will see if I can round up someone who can check out the wiring for me. Have a great Memorial Weekend.
Old 05-29-2005, 10:54 AM
sharo23 sharo23 is offline
Send a message via AIM to sharo23 Send a message via Yahoo to sharo23
the sys has diagnosis capability pull the the slyding door trouble code
first.this is done manualy and a little trikky using the overhead switch
p.m me if you need the procedure [email protected]
