Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 05-25-2005, 08:45 AM
manlion manlion is offline
ac cuts out on acceleration (Load only)
Sorry, I forgot to mention this is a 1989 GM.
Old 05-26-2005, 08:22 PM
auto trainy auto trainy is offline
Re: ac cuts out on acceleration (Load only)
It sounds right,most systems do cut off the compressor under low vacuum conditions (heavy load) also make sure the engine is not laboring,tune up ect.
Old 05-27-2005, 03:07 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
does it switch through all the vents or just plain stop
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 05-28-2005, 06:11 PM
I understand that the compressor will shut off during wide open throttle, but just the slightes amount of acceleration at any speed causes this to happen.
Old 05-28-2005, 06:14 PM
Yes, air still blows through the vents, but the compressor is not running, therefore, the air is not cold coming out of the vents. This lasts for about 4-5 seconds after constant speed is reached. It does not matter what speed I start off at.
Old 05-28-2005, 07:30 PM
Did this start before you changed the vacuum canister if not than you either have low vacuum or the PCM (power control module) is not sending the signal the the compressor relay correctly.
Old 05-30-2005, 08:22 AM
This started before changing the canister. How do I check the PCM?
