Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 05-25-2005, 04:57 AM
lodownlv lodownlv is offline
Send a message via AIM to lodownlv Send a message via Yahoo to lodownlv
head gasket, resurface?
hello all, if i resurface the head and the block on my 7mgte (no resurface work) would a hks Bead Type, 86 bore/3.0mm thick be good for me? also how much should i get the head and block cut/shaved if any to add a 3.0mm gasket. also is 86 bore standard bore? and finally i herd that if you use a 3.0mm gasket and arp bolts and studs torqued at 90 lbs! will create a perfect seal and you wouldn't ever have to change a hg again! also i herd that you need to get it resurfaced to a certain smoothness?
let me know
tks
