Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 05-24-2005, 10:12 PM
Burnout91Mk2 Burnout91Mk2 is offline
engine swap
i own a second gen mr2 n/a and i want to swap in the jdm 3sgte but my resource stopped selling the engine and i was wanting to know where i could get the engine atleast if not the whole rear clip( engine tranny wireing harness and all that good stuff)
Old 05-25-2005, 12:06 AM
bob stone's Avatar
bob stone bob stone is offline
Re: engine swap
you should just get a usdm engine, the diffrences are very small and mostly based on japan having a higher octan rating at the pumps here,
Old 05-25-2005, 10:53 PM
stockthirdgen stockthirdgen is offline
3S-GTE DOHC 4/50 94 1998 245(dyno:268)@6000 223@4000 86 86 8.5:1 13psi/0.9bar
III Gen(jdm) Facts: - MAP sensor instead of AFM - Bosch D-Jetronic (Gen III) vs. L-Jetronic (relatively primitive) engine management - CT20b turbo replaces CT26 - Boost raised from 10psi to 13psi - Fuel cut raised from 12 psi to 18 psi - Different ECU - 4 wire O2 sensor - Shim under bucket valve shims - slightly more aggressive cams - Revised internals (pistons, con-rods etc.) - Revised cylinder head cooling passages/water jackets - Revised intake manifold (8 'independent long ports' reduced to 4) - intake manifold inlet air temperature sensor added. i.e. after turbo and intercooler. - Revised gearbox with close ratio gearing - lower compression ratio - stainless steel head gasket - factory 540cc injectors replace 430cc injectors - revised fuel rail with bigger bore and relocated pressure regulator - TVIS eliminated - EGR eliminated - LSD in 80% of them - throttle body increased from 55mm to 60mm - inlet valve lift increased from 8.2 to 8.7 - intake manifold inlet air temperature sensor added - Less restrictive exhaust elbow - Aluminum oil pan - more rigid alloy sump and additional oil baffles - Factory Catch can - Better Oil Cooler and relocated oil filter (bottom) - 4 Channel ABS coupled with Traction Control available
Sorry so long, it just doesnt seem like anybody knows anthing about the JDM motors. S.B.
Old 05-26-2005, 01:01 AM
mr2envy mr2envy is offline
Send a message via Yahoo to mr2envy
Re: engine swap
wow i had no clue there was that big of a difference since the fuel cut is then at 18 instead of the 12 does that mean it would be safe to run with 17 or 18 boost on a jdm engine with all stock?
-=Prospect Motorsports=-
Old 05-26-2005, 03:46 AM
bob stone's Avatar
Re: engine swap
yes i under stand all that and I just didnt want to make a big paragraph about how all that adds up to only 45 more hp, but if you run that on the gas in usa you will NOT be making 245 hp, I actuly live in japan and have a jdm gen 2 mr2, I relize that there are a lot of diffrences with the engine, but it is puting out that much power cause it is tuned to the high octans they have here, you would be better off just getting a usdm motor for it and upgrading it with the money you save on shipping and all that rot, pluse in most cases you dont know what you are getting, cause all jdm motor swaps are usally useing lowmilage used engines, and you get what is shipped with little or no warrentty, at least with a usdm motor you will probley have a chance to see the engine runing before you put the money in to it and be able to talk with the privious owner and see what he has to saw about how it ran. pluse i cant rember but i think that motor wont pass some state smog regs ?
also it will be harder to find parts for the 3gen in the states
Old 05-26-2005, 11:08 AM
Re: engine swap
how much higher is the fuel there?
Old 05-26-2005, 12:18 PM
Re: engine swap
your right about the parts, smog, and not knowing what your getting till you got it part. The fuel difference is only 3 or 4 octane, our 94 is equal to 98 or 99 in japan. We use a differant method in the states. Also the 3rd gen is a underated motor so as not to compete with the supra that only has a 280 hp rating but actually puts down up to 353hp at the crank. Theres some agreement among makers in japan to have a 280 limit on rated hp. They couldnt have the Supra advertised as having only 10 or 20 more hp then the same year Mr2.
Old 05-26-2005, 12:48 PM
clawhammer's Avatar
clawhammer clawhammer is offline
Re: Re: engine swap
Not true at all. The 3rd gen is rated at 245 hp at the flywheel, which seems to be pretty accurate.
The gas is the same in Japan, it's just the there is a high octane number and a low octane number. Japan just uses the high octane number, but here in the US we use the average of the two. Japan 100 octane is the same as US 93 octane.
2001 Honda S2000 New Formula Red
Mods:
Engine: Comptech Air Intake Box, miscellanous chrome dress up pieces
Suspension: Comptech front strut tower bar
Exterior: Grillcraft grill, lots of wax
Interior: Rick's leather console cover, Muz one-piece luxury floormats, Rick's windscreen,
Electronics/Audio: Polk speakers
Wheels/tires: 18" SSR Competition wheels with 225/40 and 255/35 tires
Old 05-26-2005, 02:32 PM
JekylandHyde's Avatar
JekylandHyde JekylandHyde is offline
AF - Advisor
Not true.
Japanese pumps measure a DIFFERENT octane than what we have in the US. You can not compare numbers. Their is not "higher."
Secondly, the Jspec GenIII engine IS significantly better than the US engine. The head is completely different and flows much more air.
That being said, I would still stick to the US engine.
If you want to get a complete swap, call Dave Jenny at: www.paautoracing.com
Tell him I sent you and he can hook you up.
Sponsorship: Amateur Motorsports <-- Get the book! - books are now available for shipment
Old 05-26-2005, 04:14 PM
Re: engine swap
you missunderstood clawhammer, The stock gen 3 is rated at 245hp and the Supra is rated at 280hp. Both 3rd gen Mr2's and Supra's make more hp at the crank then they are rated at. I have had a hard time finding parts, but its much faster then any stock US turbo ive ever driven.
3S-GTE DOHC 4/50 90- 1998 200@6000 200@3200 3.39 3.39 8.1:1 max 11.0psi/0.75 bar
Old 05-26-2005, 06:41 PM
bob stone's Avatar
Re: engine swap
I will retract my statments and walk away with my tail between my legs hehe thanks for giving me the heads up tho, learend a lot more today
Old 05-26-2005, 10:08 PM
AF - Advisor
Re: engine swap
No worries Bob ... we are all hear to share and learn. I was not trying to be rude or anything, it is just important to me to make sure correct info is being exchanged.
God knows I have passed enough bad information in the past
