Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-24-2005, 10:02 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Boost gauge?
Anyone have any sugestions on which Boost gauge to buy? I'm trying to pump out a little more boost on my lil t-25 untill i get enough (motor wise) for the EVOIII Big 16G i have sitting in my gurage... so naturally i need a gauge that reads pretty high boost levels, also i would really like for it to match the stock gauges, but i cant find any that glow that strange yellow the stock gauges do. also suggestions on the best place to mount the gauge? (A-piller; "cluster dash") and are there any other gauges that i should look into? kinda shoothing for somewhere around the 300hp range...so any advice also would help! Thanks!
Old 05-25-2005, 12:15 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Boost gauge?
autometer makes good gauges. get a gauge pod for the A-pillar with either 2 or 3 holes. you'll end up filling it up with other gauges as you want more hp. 300 out of a stock t-25 is pushing it. also you might need to upgrade a few things besides just cranking up the boost.
p.s. you need a manual boost controller if you plan to turn up the boost too, if you don't already have one.
95 Talon TSI AWD
97 Eclipse GST
Old 05-25-2005, 08:25 AM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
Re: Boost gauge?
I agree with autometer and I wouldnt worry about the gauges matching your stock gauges if your going to get a pillar pod cause they look cool no matter what.
P.S. you have 2 threads about this please delete one.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 05-25-2005, 02:56 PM
Black99GST's Avatar
Re: Boost gauge?
i would delete the other one...but i'm not sure how...thanks for the info! I have the boost controller...i'm following DSMtuners.com's guide...so i'mma get there supporting mods aswell...are there any other gauges i should look into while i'm @ it? thanks!
Old 05-25-2005, 03:35 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Boost gauge?
autometer carbon fiber gauges have the same color lights as our car's. i chose to get the cf 30vac/30 boost, cf olectric oil pressure and autometer 2 gauge a-pillar. looks great
DSM geek
Old 05-25-2005, 09:27 PM
Black99GST's Avatar
Re: Boost gauge?
does autometer make white faced gauges that glow the same as stock gauges? * i really would reather have blue glow... but i want it all to match* how would i go about changing the glow color on my stock gauges? Impossible? anyone know? thanks
Old 05-25-2005, 11:26 PM
Re: Re: Boost gauge?
i had a buddie change his dash lights to blue. granted it wasn't an eclipse (91 cavalier) but the process should still be the same. you'll need to remove the gauge cluster and pull it apart and replace the bulbs with some blue ones. just make sure you replace only the ones that light up with the lights and not the dash warning lights, or you'll get a different color. (ie, BRAKE light is red with a white bulb behind it, you put a blue bulb behind it and you'll have a purple BRAKE light.
95 Talon TSI AWD
97 Eclipse GST
Old 05-26-2005, 02:27 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Boost gauge?
I have seen many vac/boost combo guages be inaccurate, or lose accuracy over time. I have also seen poeple upgrade from a 20 psi guage, to a 25, then to a 30, etc. I went with a 0-35 psi (autometer sport comp) 5 years ago, and its still balls on today. Make the right choice the first time, whatever that is in your particular case, so you can move on to bigger and better things.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-26-2005, 03:11 PM
Re: Boost gauge?
yeah, accuracy is a diffrent story with my cf vac/boost gauge! if you want a blue light, just buy the gauge you want and get a blue bulb. problem solved.
DSM geek
Old 05-27-2005, 01:39 PM
Black99GST's Avatar
Re: Boost gauge?
alright, anyone have like a how too on changing the stock gauges glow to blue? its a 99 w/ the white face gauges if that matters... BLUE WOULD BE KILLER! also, is it possible to change the A/C controles to blue glow as well?
Old 05-27-2005, 02:33 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: Boost gauge?
Just something you might be interested in:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33682
You got a 35 psi boost (no vac), and two filler gauges for a triple pod. Seems like a good deal.
http://cgi.ebay.com/ebaymotors/ws/eB...category=38660
The above have a cool blue backlight...check out the link.
Also, you should go to www.speedhut.com. They custom make various gauges, and you decide on everything, from the font to the color you want the gauge to be... they even do custom boost gauges, tachs, and hvac, everything...well worth looking at IMO.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 05-27-2005, 04:01 PM
Shpyder's Avatar
Moderate moderator
Re: Boost gauge?
http://www.speedhut.com/el_detail_ga...ber=439&bhcp=1
This is what youre looking for...no vac, 30 psi straight boost, customizable to the max!
Old 05-31-2005, 08:16 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
http://www.angelfire.com/fl5/import/console.html
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
