Old 05-24-2005, 08:54 PM
DRW1000 DRW1000 is offline
ABS Revisited
Well my Windstar is running great. I only have one annoyance left.
My ABS light is on and It has not activated since the light came on. Here are some points:
-Changed front pads and (rear shoes should be okay)
-Bled the brakes
-Tried to remove brake resevoir but it did not easily come off so I was afraid to force it. I was planning to remove the fluid from here rather than force it through the system.
-Checked two fuses (relays) in front fuse centre
-Checked fuse in vehicle
Removed rear sensors from drums and wiped clean (could not find my brake clean).
-Disconnected and reconnected wiring harness to ABS module.
-Checked tire pressure.
My ABS light is on from the moment my car starts. It does not require a short drive to turn it on. I think this indicates that the sensors themselves are not the trouble but I am not sure.
Does anyone have any suggestions? I can live without the ABS but the stubborness in me keeps looking at the light.
Thanks
Old 05-25-2005, 07:16 AM
CoachKarl CoachKarl is offline
Re: ABS Revisited
Hello DRW,
My mechanic neighbor friend talked me into replacing ALL the brake fluid in the system. I pulled the plastic resevoir off, dumped it in the oil bucket. Then washed & dried it till it looked like new. Plopped it back on the Master cyl, and pumped all the old fluid out of the lines. He swore it would save my ABS.
I've also taken to searching all automotive forums looking for answers. There's got to be an "automotive electrical nightmare" site out there somewhere. Try plugging ABS FORD PROBLEM into google and see what that digs up.
And no, your'e persistance is not a fault in my book. What you have is patients, self control & curiosity. You'd make a good computer programmer!
Karl.
Old 05-25-2005, 09:25 AM
Re: ABS Revisited
Thanks for the response Coach,
Did replacing the fluid fix your ABS or was this a preventative maintenance move?
How did you remove the resevoir? Did you just pull up?
I seem to think I have a mechanical problem and not electrical.
Computer Programmer eh?....lol I am actually an Electrical Engineer so it expalins my persistance I imagine.
Old 05-25-2005, 10:32 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: ABS Revisited
Have you had a scanner that is capable of reading the ABS system? This will narrow down the problem and let you keep more of your hair. Usually if the light stays on from start up, it is either the control module or a wire that is broken or shorted. The scanner will point you to an area. Good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 05-25-2005, 12:02 PM
Re: ABS Revisited
It was preventative maintenance.
You just pull up on the resevoir. Make sure it's completely dry before re-installing.
Yeah, system loving fools aren't we?
Old 05-25-2005, 12:51 PM
Re: ABS Revisited
Coach,
Is it an o-ring that seals the resevoir to the "other part"?
Old 05-25-2005, 12:53 PM
Re: ABS Revisited
Way2old,
No My scanner is just for PCM codes. You did answer a good question though. My light is on from start up.
Old 05-25-2005, 08:01 PM
wiswind wiswind is offline
Re: ABS Revisited
There are "C" codes for the wheel sensor failure codes....they are read at the same connector as the OBDII codes. A code reader that can read "C" codes should be able to read them.....I have not tried it myself....but there are about 13 codes just for the wheel sensors...that will tell you specifically what wheel sensor.....and the problem.
The "C" codes cover a bunch of other brake system failures as well. I do NOT know if the "C" codes will light up the CEL.....
Seems they very throughly cover the ABS system....from looking at the list on Aldatadiy.
So...I think it would be very much worth your while to get the "C" codes read.....otherwise...it is a guessing game.
Brake fluid. I flushed my brake fluid last year as a preventative maintenance measure. The main place for contamination (as long as you keep the master cylinder cap on...and use ONLY fresh fluid from a NEW SEALED bottle) is at the wheels.
I used a "Mighty Vac" brand hand pump to bleed the fluid through the lines at each wheel....starting at the Back Passenger side....to Back Driver side, to Front Passenger side....to Front Driver side. This is starting from the longest run......to the shortest run.
I used Motorcraft brand of brake fluid as it has a much higher dry boil point than DOT3 / DOT4 minimum requirements. And a much higher dry boil point than anything I could find at the autoparts stores...... 550 degrees F. You can match or better that at a racing supply house......but not by much.
Personally....I think doing that on a older vehicle is a good idea....and perhaps....bleeding a small amount at each wheel...say every year or every other year.
Brake pad replacement procedures that I have read....seem to tell you to remove 1/2 of the fluid from the master cylinder....then push the caliper piston in....forcing the fluid up into the master cylinder. Much easier.....much faster....but.....at risk of putting crud into the ABS unit.....
I prefer to hook up my "Mighty Vac" brake bleeder pump to the bleeder screw..... Pump up some vaccum (my pump has a gauge) and open the screw until some fluid comes out. Then.....keeping vaccum on the vac gauge.....I slowly push the piston in as directed in the instructions ( "C" clamp with wood block). This way....the worst fluid in the system (heat stressed, and contaminated) is pulled out....and disposed of.
I always believed that when brakes were done....that the brakes were bled....but if they follow the instructions.....that is NOT true.
I always had my brake work done for me (I have been very lucky...and brake linings lasted a long time).....but when I bled my brakes myself....for the first time last spring....I pulled 3 bottles of coffee colored fluid out at each wheel....nasty stuff....it was.
Old 05-25-2005, 10:16 PM
Re: ABS Revisited
Thanks for the info Wiswind. I know I should have the brake codes read but I want to exhaust other possibilities first.
I have access to a Ford manual and it mentions something about C111 (the ABS control module connector) being under the dirver's seat. I though this odd since I though it was near the brake booster. I looked under my seat and did not see it. I wonder if it is under the van. Has anyone heard of a part of the ABS system under the seat?
I will have to re-check the manual tomorrow.
Old 05-26-2005, 07:22 AM
12Ounce 12Ounce is offline
Re: ABS Revisited
Its under the seat, under the floor pan.
Old 05-26-2005, 08:33 AM
Re: Re: ABS Revisited
Okay really dumb follow up here-
This means outside the van.......correct???
Thanks 12ounce.
Old 05-26-2005, 10:29 AM
Re: ABS Revisited
Yep, underneath where all the brake lines are grouped ... fairly close to the in-line gasoline filter.
If you have to remove this thing ... get ready to bust some knuckles. And "flare nut" tube wrenches are a must.
Old 05-26-2005, 09:12 PM
steve_o steve_o is offline
I have a '99 3.8L and had my ABS error codes read today.
C1185 Power Relay Output Circuit Failure
C1198 LF Isolation Valve Circuit Failure
C1210 RF Dump Valve Circuit Failure
C1214 RF Isolation Valve Circuit Failure
C1242 LR Dump Valve Circuit Failure
C1246 RR Dump Valve Circuit Failure
C1250 LR Isolation Valve Circuit Failure
C1254 RR Isolation Valve Circuit Failure
I think this set of ABS failures set off these traction failures
C1404 RF Traction Control Valve Circuit Failures
C1410 LF Traction Control Valve Circuit Failures
The mechanic who read these was too busy to actually diagnose the issues ($$$).
Does anyone have any ideas what this all might mean?
Steve
Old 05-26-2005, 10:56 PM
Re: ABS Revisited
Staggering!
Welcome Steve O,
My best guess is . . . . that the gizmo with all the brake tubes that DRW is now inspection under the drivers seat of his van, is the source of your your problem too. I've been replacing all the brake fluid in the system when I do a brake job, (at the insistance of my annoying Porsche/Audi/VW mechanic neighbor), and have had no problems. Flush it all out PROUFUSELY. Clear the codes. Let us know how it turns out. Pour the old brake fluid in with your waste oil.
Karl
Old 05-27-2005, 07:15 AM
Re: ABS Revisited
To have so many codes, I wonder if your module is not disconnected ....or harness damaged.... have you run over a bunch of road debris recently?
