Old 05-24-2005, 09:52 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
smog pump super charger?
i read on one site that you could hook up a smog pump as a super charger. i know that they have decent psi and cfm but the site said that you would need 4-6 of them for decent performance from a V8. i thought of using 2. i have the 4.3 CPI. would this work? i would put more on but space is very limited to this motor. would this work or what other things might i be able to pick up at a junk yard cheap that will work?
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
Old 05-24-2005, 11:00 PM
Schrade Schrade is offline
Re: smog pump super charger?
Sounds like a good idea, except for the part about 4-6 of them??? Where are you gonna' put 4-6 smog pumps?
Did the site mean 4-6 lbs of boost?
Even 2 smog pumps is gonna take a little hocus-pocus. Now if you could put a bigger pulley on the pump itself, and then split the airflow, with some air going to the intake, then you might be onto somethin'...
Old 05-25-2005, 12:02 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
smog pumps put out air flow, with little pressure.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-25-2005, 12:09 AM
True, LT, but how 'little'?
So with a LARGER pulley, as opposed to undersized pulleys which supposedly give more HP, how much more CFM's would a bigger wheel give. I think there's something there...
Old 05-25-2005, 12:22 AM
BlazerLT's Avatar
AF -Advisor
CFM is airflow, PSI is air pressure.
This pump is not made for high pressure or high flow.
Just drop it, it will not work.
Old 05-25-2005, 07:57 AM
i think he does have a good point. if i were to run 2 of them and run them faster with a smaller pulley then i should be able to get at least 3 PSI from it. even that small amout is better then nothing at all and it will give you some boost in power with out over doing it or shortning the life of the motor. the guy also clamed that for a very short period of time he could get 60 psi out of it. he also clamed that with a 5 hp electric motor hooked up that if you put a cap ont the exhaust side of the pump that it would stop the motor. i don't know about stoping it but it would have slowed it down. heres the web site.
http://www.richmondlabs.com/Automotive/DCSP.html
Old 05-25-2005, 07:58 AM
heres the web site with a post on it.
http://www.richmondlabs.com/Automoti...argerPost.html
Old 05-25-2005, 11:14 AM
Fireplug Fireplug is offline
Why on Gods Green Earth would you want to do some thing like that. First the amount of horsepower needed to run 2 or more pumps would wipe out any boost. 2nd with GM known for crap gaskets why would you want to add any boost to a engine that is NOT set up for it.
Old 05-25-2005, 01:22 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: smog pump super charger?
EXACTLY!
Old 05-25-2005, 09:25 PM
You can't say it won't work unless you've tried.
The only part that seems hard to figure is the part about 2 pumps. Seems to me there's no room for extra components, but with an oversize pulley, you're gonna get more air flow from the pump.
Old 05-25-2005, 10:51 PM
And just how do you control the boost?? How do you read the boost going into the engine?? I never said it would not work read my post
Old 05-26-2005, 12:42 AM
BlazerLT's Avatar
AF -Advisor
Gimmie a break, no offense, but why don't you do some research on low pressure smog pumps before you question what we say.
If this was that easy, don't you think everyone would be doing it?
Old 05-26-2005, 03:28 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Can't blame you for wanting to try it. But I agree with the guys . It does not have the volume . You would have better luck adding a leafblower to it with a power inverter. I did a water injection on a FI engine 20 years ago that gave it more power than the smog pump could . Rob
Old 05-26-2005, 08:44 AM
now how is water injection going to give you more power? i thought water killed the motor. i don't know to much about so fill me in. to measure boost any boost on the motor you would just pull the tube from the back of the intake and put a T on it to split it to the gauge.it has a vacume on it or boost. its part of the intake. or if you really want you can pull the intake and drill in a new plug.
Old 05-26-2005, 09:21 AM
blazee's Avatar
blazee blazee is offline
Problem?
You guys are making this way to complicated. If you want to get a boost:
Pull the line going to your windshield washers off and tie it pointing into the throttlebody.
Fill your washer resevoir with racing fuel.
When you want a boost just hit your washer button.
