Old 05-24-2005, 08:17 PM
gonzales7727's Avatar
gonzales7727 gonzales7727 is offline
Hot Air
hey guys, 96 z-24, blowing hot air, last summer replaced all the hoses and today replaced the fan, about 65 lbs in it right now and still nothing, anyone wanna give it a shot?
Old 05-27-2005, 09:50 PM
Re: Hot Air
come on fellas, I posted this 2 days ago and none got any clues, how about suggetions.
Old 05-27-2005, 09:53 PM
alphalanos alphalanos is offline
blowing hot air from what? A/C?....under the engine?
96 EJ6. Future home of boosted B18C1.
Old 05-27-2005, 10:25 PM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Re: Hot Air
Turn the little knob so that the white section is pointing towards the blue instead of the red.
MAKE ART, NOT WAR
Old 05-27-2005, 10:31 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: Re: Hot Air
Take a hammer to it. When that doesn't work, take it to a AC repair place to have them look at it, they'll probably tell you the AC clutch is out or the compressor is stupid or something, but I'd not screw with Freon if I were you.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 05-28-2005, 12:57 PM
Re: Hot Air
bunch of funny fuckers here huh?!
yes the ac and I don't trust anyone around here that does ac
any other clues
Old 05-28-2005, 11:35 PM
well, you probably need freon. so youre going to need someone that is certified to work on A/C systems. if you can live with no AC then you will probably save some money...
Old 05-29-2005, 09:44 AM
Ryan066 Ryan066 is offline
yup, the only way your getting your AC back is if you bring it into a shop... there is a special machine that you need to put more freon (sp?) back in... chances are you have a leak in the lines.
Old 05-29-2005, 11:34 AM
i3o2Matt's Avatar
i3o2Matt i3o2Matt is offline
Send a message via AIM to i3o2Matt Send a message via Yahoo to i3o2Matt
Re: Hot Air
65 lbs of what??? i hope to god ur not sayin refrigerant...please tell me ur not talkin bout refrigerant (freon) even if u meant 6.5...that is still bad...
Old 05-29-2005, 12:43 PM
caviman69 caviman69 is offline
Re: Hot Air
After so long the freon will go out and you have to get it refilled. If your car is a 96 and you have yet to get it done. My car hade the same problem and its a 2000. Go somewhere else if you dont trust the poeple around you.
Old 05-29-2005, 03:22 PM
Re: Hot Air
ok, i meant to say .65lbs, I already drained it myself and added freon, checked for leaks, nothing, and i also changed all the lines last summer and put in freon and it worked all summer but know it's blowing hot, and it's for my wife not me.
Old 05-29-2005, 06:31 PM
Re: Re: Hot Air
maybe the door is stuck to hot, can u here it closing and opening when you switch it over to cold?
Old 05-29-2005, 11:01 PM
i3o2Matt's Avatar
Re: Hot Air
.65 is low...usually its like almost 2 lbs dude...i just took HVAC in college for auto technology...saturns hold like 1.7lbs...i think thats ur problem right there....also did u make sure u put oil back in if any came out?? did u pull a vacuum n do all those things associated with it?? HVAC isn't somethin to fuck around with
it should tell you under the hood or in the service manual how much refrigerant goes in there...as well as how much oil.
Old 06-05-2005, 07:37 PM
Re: Hot Air
well, i had about 2.5lbs in it before, but i drained it, do you think getting it vaccumed and recharged, will help?
Old 06-06-2005, 04:30 PM
i3o2Matt's Avatar
Re: Hot Air
yeah...u need to do a recovery...pull a vacuum on it..look on the compressor as to how much is supposed to be in there...make sure it holds a vacuum...add oil if any came out...then put the amount of refrigerant in that is needed
