MAP sensor problems
so... think my map sensors pooched...
when the car warms up it idles up and down from 2000 to 1000 or lower.. i have a boost gauge hooked upto the map sensor currently just so i can have all the lines ran untill i can tap the manifold when i have time. but anyways... when its idleing up and down the vacum goes up and down, so i'm assuming the map sensors pooched... what do u guys think?
94 s-10 bagged, body dropped, 22's, suicide coupe doors, fully shaved, and soon a small block 350 2011 Silverado... Stock Daily driver
Re: MAP sensor problems
no check engine lights? check your ecu for codes even if you don't have a CEL...if not, then you may have a damaged vaccuum line.
if you have a CEL for the map sensor, then it could either be the sensor or a vacuum line itself...check those first.
no CEL, no MAP code... no vaccum leaks since i just replaced all those lines with silicone lines.
figured it out, it was the TPS, just unplugged it and it runs like a charm
