Old 05-24-2005, 07:16 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Exhaust Manifold Questions
Just a few Q&U:
1) Does the manifold have a bolt tightening/loosing sequence? The Haynes manual said nothing about it.
2) What is the best way to take off the manifold? Like after taking off the bolts, and it's not even loose, how can I take it off? I tried prying it off, but nothing worked. It's SO rusted on.
That bitch won't move. Thanks
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 05-24-2005, 07:51 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Exhaust Manifold Questions
if you have the heat sheild off, run the car for a bit to heat it up, then use a breaker bar to bust the bolts loose.
DSM geek
Old 05-24-2005, 09:12 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
If you have all of the bolts off, take a rubber hammer to it.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 05-24-2005, 09:31 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
good luck! it took me 4 hours to remove my bolts after i got the heat shield off. They were all rust on. The hard part was the bolts by the t-belt under the header manifold.
oh yeah i forgot I used wd-40 and it made it easier. I stepped on mine. Also I removed my radiator to have more room.
....It has been a LONG time...I want to move to FL or Japan.....
Old 05-25-2005, 12:40 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
P.B. Blaster for the bolts/nuts. it'll make it 10x easier to get them off.
are you sure ALL the bolts are off?? i don't remember my manifold being stuck to my head. i don't think they can stick or rust together.
95 Talon TSI AWD
97 Eclipse GST
Old 05-25-2005, 12:20 PM
kjewer1 kjewer1 is offline
AF - Advisor
I dont see how a cast manifold can rust to an aluminum head either, even if there wasnt a gasket between the two
There is no specific need for a torque sequence, but anytime you have surface that is supposed to stay flat being fastened to something, it makes sense. When in doubt, start in the middle and work your way out, alternating top and bottom. No different than any other torque sequence, the strategy is the same. Spead the force evenly. Starting at the outside will lock the ends down, and if the surface is not flat, tightening the middle bolts afterwards will put unnecessary stress on the surface, resulting in poor sealing or warpage.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-25-2005, 04:44 PM
david-b's Avatar
Dave is THAT guy
It just wouldnt come off. All the bolts are off, and it didnt move. I tried a rubber mallet, didnt work, and a HUGE old-school tool (I dont even know what it was.. was my grandpas), and it just moved very little. The left corner slightly lifted. Running the engine and heating it up would work? Sounds kinda weird. Ill post pics of the manifold when I have time. Im thinking of just taking it to a shop and get er done there. I like doing work myself, but then I don't have to worry about it. I did use liquid wrench to get the bolts off.
Side note: Also, when doing that, you want to make sure that when using a rachet with long extenders on. My boss actually told me this. The longer extension won't strip or break any nuts/bolts.
75 Monte Carlo
Old 05-25-2005, 04:56 PM
drewh4386's Avatar
handle or extension I used extensions for reach and the long rachet for torque
